Question about Amana ATF2136ARW 33" Top Freezer Refrigerator w/ 21 Cu. Ft. Capacity, Automatic Icemaker & Adjustabl...
Condenser fan not working
Hot refrigerator walls
  • 11,896 Answers
Check power to fan with voltmeter to determine if it's the power supply or the the fan motor itself. You can get manual and parts at repairclinic.com
Posted on Sep 12, 2009
It starts flashing VACUME CONDENSER after 24 hrs on my sub zero 690 side by side fridge .I cleaned the condenser but some one suggested I can wash with hot water spray bottle (I did not tried).If there is...
"Vacuum Condenser" light on this refrigerator will appear if you have any kind of issues - some of their models would have "Service" light instead of Vacuum Condenser. As My expirience shows Most likely Your Fresh food section is low on refrigerant - Evaporator might leak freon - so what we would have in this case - compressor runs for longer time then suppose to - as a result "Vacuum Condenser" or (some models) "Service" appears. Another sigh of low freon pressure people would notice ice build up on the back wall of the refrigerator section on the left side on the middle. I post video on my YouTube chanel, so u can check how to fix it properly.
Oct 27, 2013 | Sub-Zero 690 Side by Side Refrigerator
The divider wall between refrigerator and freezer is extremely hot
Condenser is dirty our the condenser fan not working. Remove back and check fan. If not working check voltage coming to fan. If 120 volts, replace fan. If no power, bad board, located far left corner next to compressor.
Aug 17, 2012 | Refrigerators
The black panel between the refrigerator and the freezer is very hot to the touch seems very strange. What could be causing this section of the wall to over heat? We have just turned off and restarted the...
the reason of that wall becoming hot is because the condenser fan is not doing its job, here is how to check ,open tha lower back panel of the unit and make sure that the fan is running if not checkm if itgets 110 volts if yes replace the fan. if the fas is running get a long brush and clean well the condenser coils hope this helps
Sep 05, 2011 | KitchenAid KSCS25FKSS Side by Side...
The wall between the side by side refrigerator and freezer is extremely hot to the touch. Model # HSS25IFMWW
hot wallson a fridge could be 2 things first check in the bottom bak if the condenser fan is working 2 clean the condenser coi with a long brush, you will see results in a few min
Sep 04, 2011 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Door gets warm
Warm is normal hot is not. Too hot is an indication that the condenser coils are overheating due to being dirty or a bad fan motor. See the link below for details I put together on this. Let me know if it helps.
Hot Condenser
Jun 03, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
My side by side refrigerator is very hot at the divider wall between the Freezer and refrigerator just below the door handles on the front of that wall.
there is a hot gas line that runs there to keep condensation from forming,if it is hotter than it used to be suspect the condensor fan motor
Jan 10, 2010 | Refrigerators
The panel separating my side by side refrigerator from the freezer is hot - nearly to the point of burning. Kenmore model 10653606202
  1. check if the evaporator fan motor is running (inside the freezer)
  2. Same for the condenser fan motor on the bottom in the back of the fridge
  3. Clean condenser coils underneath or in the back of the fridge
  4. if there is a frost on the back wall in freezer - you've got the defrost problem, check defrost heater, defrost bimetal thermostat, and defrost timer
Oct 14, 2009 | Whirlpool GS6SHAXLS Side by Side...
MY FREEZE DOES NOT FREEZ BUT IS COOLD DOES IT NEEDS GAS
When the compressor is running, two fans should be running. One inside the freezer compartment that moves air over the evaporator coils. The other is under/behind the fridge that cools the condenser coils.
If the fan on the condenser coil (the one under/behind the fridge) stops working, the system cannot dissipate the heat from those coils, and thus cannot sufficiently cool the inside of either the freezer nor fresh food compartment.
On mine, when the condenser fan failed, I noticed right away. The front face of the wall separating the compartments became very hot. Extremely hot.
Apparently the refrigeration system is designed so that waste heat keeps condensation from forming where the magnetic gaskets on the door need to seal. When the condenser fan failed, there was too much waste heat (because no heat was being dissipated from the condenser coils by the fan), thus making that gasket-sealing area very hot.
If it is your condenser coil fan, you can relieve the problem temporarily by removing the bottom back panel from the fridge and aiming a box fan (a regular room or window fan) at the condenser coils. This will circulate air over the coils, thus removing heat from the coils.
Jul 29, 2009 | GE GSH25JFR Side by Side Refrigerator
Center partition wall of refrigerator is hot !
Sounds like your condenser fan isn't working...Take the back cover off to see if there's anything stuck in the fan blades. Usually when the fan stops, the compressor & tubing that runs between the doors get really hot. You may also want to clean your condenser coils.
Feb 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
54 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
