Question about Nokia N70 Cellular Phone
I cant access the web eventhough I used the "Go nokia n70 ;2951"
What should i do?? whats wrong... i have p10 load
  • ralowiczlive
    ralowiczlive May 11, 2010
    Do you have a data account set up with your cellular provider?
    President:
  • Nokia Master
  • 511 Answers
Try to get a new setting from your service provider nd save as default ur work is done...
Posted on Sep 12, 2009
Can not access web interface
I think you're out of luck. If you had posted this info with the 5 other posts you made you would have gotten this answer sooner.
You have over-written the PROM on the AP with garbage.
You could contact Engenius and see if they will flash the PROM with a working image otherwise you have a piece of junk.
Mar 20, 2014 | EnGenius EOC-5610 802.11a/b/g Wireless...
We are getting a F51 code on our washer. What does that mean?
Hi
F51 error is a rotor position sensor error. This error appears when rotor position sensor is faulty or due to a faulty control board. Look underneath the tub and check the motor, check for RPS on the right side (follow the brown wires) and under the motors rotor disk. Use allen wrench to remove the rotor and then the four bolts holding the motor stator to the tub can be removed. You would need to check the motor by running Motor test. Please follow the steps ---
1. Unplug washer or disconnect power.
2. Check to see if basket will turn freely.
3. If basket turns freely, go to step 4. If basket does not turn freely, determine what is causing the mechanical
friction or lock up.
4. Remove the console to access the machine/ motor control assembly.
5. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 6.
If visual checks fail, reconnect P5 and P10 and repeat step 1.
6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7 and verify that the resistance is within the range.
If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to next step.
7. Tilt machine forward to access the bottom of the machine and the drive motor area. See Figure 1 on page 6-13. Remove the motor bolt, then the motor cover to access the motor connections.
8. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check passes, go to step 9.
If visual check fails, reconnect the electrical connections, reassemble stator and motor cover and repeat step 1.
9. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector. See Figures 2 and 4, pages 6-13 and 6-16. If there is continuity, go to step 11. If there is no continuity, replace the lower machine harness.
10. With an ohmmeter, check for continuity between all pins on the P5 machine/motor control connector and the drive motor connector. If there is continuity, replace the drive motor. If there is no continuity, replace the lower machine harness.
11. The drive motor and lower harness are good. Replace the motor RPS board and perform the Diagnostics test in step 1 to verify repair.
12. If the Diagnostics motor test in step 1 failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Motor Diagnostics in step 1 to verify repair.
Nov 16, 2010 | Maytag Bravos MTW6600T Top Load Washer
What is code F 51
Hi
Thanks for using FixYa and I am sorry to hear whatever happened. Error
F 51 flashes when there is a motor rotor position sensor (RPS) failure. Please follow the step by step instructions to resolve this issue: This test checks the wiring to the motor and rotor position sensor; and the motor and rotor position sensor themselves. NOTE: Drain water from tub.
1. See Activation of Manual Diagnostic Test Mode, and check the motor and electrical connections by performing the Agitate and Spin tests under Manual: Motor. The following steps assumes that this step failed.
2. Unplug washer or disconnect power.
3. Check to see if basket will turn freely. If basket turns freely, go to step 4. If basket does not turn freely, determine what is causing the mechanical friction or lock up.
5. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 6. If visual checks fail, reconnect P5 and P10 and repeat step 1.
6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7 and verify that the resistance is within the range. If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to step 7.
7. Tilt machine forward to access the bottom of the machine and the drive motor area. Remove the motor bolt, then the motor cover to access the motor connections.
8. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check passes, go to step 9. If visual check fails, reconnect the electrical connections, reassemble stator and motor cover and repeat step 1. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector. If there is continuity, go to step 11. If there is no continuity, replace the lower machine harness.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does F51 mean? This comes up on screen. Also leaks from the bottom.
Hi
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error message F50
F50 means that the Rotation Position Sensor doesn't sense any movement from the motor.
2. Check to see if basket will turn freely.If basket turns freely, go to step 3. If basket does not turn freely, determine what is causing the mechanical friction or lock up.
3. Remove the console to access the machine/motor control assembly.
4. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 5. If visual checks fail, reconnect P5 and P10.
5. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3.Also measure the resistance at the P10 connector between pins P10-1and P10-7 and verify that the resistance is within the range. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range.
6. Tilt machine forward to access the bottom of the machine and the drive motor area. Remove the motor bolt, then the motor cover to access the motor connections.
7. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check fails,reconnect the electrical connections, reassemble stator and motor cover.
8. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector.If there is no continuity,replace the lower machine harness.
9. With an ohmmeter, check for continuity between all pins on the P5 machine/motor control connector and the drive motor connector.If there is continuity, replace the drive motor.If there is no continuity, replace the lower machine harness.
10. The drive motor and lower harness are good. Replace the motor RPS board and perform the Diagnostics test.
11. If the Diagnostics motor failed, then the machine/motor control has failed: Unplug the washer or disconnect power.Replace the machine/motor control assembly.
Thank you !!
Jun 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
How do i get the top of the mixer off to fix the gears? i'm unable to find a way to remove the lid.
You mean the transmission cover: here what I did to removed it: all item number reference to part catalog
1- remove top cover (# 1, p10)
2- removed 4 crews #55,56 p10
3- remove cap bearing retainer (#9, p10))
4- remove #1,2,3,4 p14
5- remove retainer twin bearing (#8, p10)
6-remove #32,33,34 and 45,46,47 p14
7- remove 4 crews (#32 p10) and pull out shift handle assembly
8- use a wooden rod (1/2 ") and push though the shift handle access and up to the transmission cover to push out the cover, be carefull not to damage gear tooth.
Good luck and have fun
Apr 18, 2010 | Hobart A200 Stand Mixer
Sending failed
Soo the solution is u should delete all messages from inbox and outbox, then try to send a new message and voila it is working
Jul 15, 2009 | Nokia 1100
Message sending failed when texting...eventhough my unit have a sufficient load...i can even call...but cant send SMS.
hi thanks for using fixya!!
If you have sufficient load and your simcard is working fine, meaning you be able to call and receive calls.
You have to verify the message centre number, please contact your provider. the message centre number is the responsible for you to send messages.
If you need further assistance, let me know.
Nokia 6300 java accesss point problem
other browsers are not supporting your mobile
Jul 14, 2009 | Nokia 6300 Cellular Phone
Nokia N70 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
