Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Describe your Husqvarna "Chain Saw -
Describe your Husqvarna "Chain Saw - 16" Bar, 3 Hp Problem Wont start, havent got a manual
    Brigadier General:
  • 4,088 Answers
Remove the spark plug and test for spark. If ok, try some starting fluid in the plug hole, install the plug, and try to start. If it runs a short time, it is not getting fuel. Check fuel lines including inside the tank. Clean or replace the air filter. If this saw is fairly old, the carburetor probably needs a re-kit and cleaning. Does it have good compression? Check the muffler for plugging. Make sure the fuel/oil mix is fresh. Good luck!
Posted on Sep 12, 2009
How do I sharpen the chain
There are plenty off the shelf devices to aid chain sharpening, Husqvarna do a simple roller gauge, easy to use and very effective.
May 29, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan " Wild Thing
It is running lean, they always need to run a little on the rich side free running, once the engine is loaded it will then need the excess fuel, it runs ok without the bar and chain because there is no load, start by replacing the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of fuel leakage, replace if reqired, if the carb has standard adjuster screws, increase the H screw by 1/4 turn out ( anto clockwise ) this will richen the mixture.
Aug 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Describe your "Chain Saw -
A couple of things too check here, remove the air filter and clean, remove the spark arrester gauze in the top of the muffler, it is held with a single screw, once the screw is out pull the tab to the side and out, this gauze should be clear and not full of carbon, clen or leave out.
Aug 21, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Looking for a repair manual for husqvarna 136 chainsaw
Below is the link to the Husqvarna website where you can download a repair manual for free. Click the link and just find the year of your chain saw and you are good to go!
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=136&types=O
Oct 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I need french manuals for my chain saw model 235 and registration quick start guide is english only
You can download the owners manual in French at this helpful website:
http://www.husqvarna.com/ddoc/HUSO/HUSO2011_USen/HUSO2011_USen__1154210-49.pdf
Oct 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do I tighten the chain for model 136?
A link to a 2003 Husqvarna 136 follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2003/HOUS2003_O0301010.pdf
See pages 7 and 8 for chain adjustment installation/adjustment.
All Husqvarna saws may be found here:
HusqvarnaUSA.com
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Sep 07, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Change chain and bar on model 235
It can be found on page 13 of your manual; about as clear as mud.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_5451676-63.pdf
Try my manual. much better; see page 16.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_1150154-95.pdf
If you are asking where to purchase a new bar and chain try here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Oregon part numbers are easily converted to other manufacturer's part numbers.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 30, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hi, I took off the clutch cover for my Husqvarna 136 saw and I can't get it to go back on. Any suggestions?
you need to disangage you chain brake band as it is engaged and wont go over the the clutch hub sprocket
Aug 05, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna mod 41 chain saw wont start
If checking spark make shore the out side if plug is earthed to chain saw.
Fresh clean fuel, clean fuel filter filter pull exhaust off and check piston is ok. Than check for flooding. start there.
Jan 03, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
173 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
