Question about Whirlpool Microwave Ovens
The fan will not stop running,says locked - Whirlpool Microwave Ovens
Samsung wall oven fan continues running after the oven has cooled down. What is causing this?
Posted on Feb 22, 2013
  • Whirlpool Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it's still running, is it the hood vent exhaust fan (which you can normally turn on and off manually) or the internal cooling fan (which normally comes on automatically whenever you microwave)?
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly with your brand, model and symptoms for more FREE help & do-it-yourself advice.
Please include this URL, too:
http://www.fixya.com/support/t2929351-fan_will_not_stop_running_says_locked
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 12, 2009
When cooking the fan doesn't run anymore. When I start cooking food the fan used to start right away, now it runs for a few seconds then stops but the food is still being heated.
The fan, a door switch, or control board relay may be causing the fan issue. Running the MW without a fan will not only cause steam buildup inside the cavity, it will cause the magnetron to overheat. If the MW has a thermal protector on the mangetron, it should shut the oven off when the temperature gets too high.
Nov 08, 2017 | Microwave Ovens
Fan failure /Intermittent heating
quite likely your microwave is trying to prevent it self from self destruct, because if the fan is not keeping the electronics components cool enough while its running the high limit thermo will disconnect power from the heating circuit, if the fan is not working it should be replaced , that's a techs job.
Feb 12, 2014 | Microwave Ovens
Microwave runs constantly
you have a door inter lock sw/ failure . replace the sw. there 3 .. ir they click there probably good . one of them does not click . primary sw secendary sw . and mont sw . .. a very common problem with all brands of micro's //
Jan 04, 2010 | Maytag Appliances Over-the-Range Microwave...
Microwave is still running when the door is open
The cooling fans run for a time after the magnatrons have stopped, The magnatrons are the heating components so I dont think you are in any danger as the microwave doors are double locked so the magnatrons cant run once the door is open
Sep 27, 2009 | Panasonic Microwave Ovens
The Display on my microwave says "LOCKED"
The control lock shuts down the control panel pads to avoid unintended use of the microwave oven. To unlock/lock control, the microwave must be in standby mode, touch and hold stop/clear for 3 seconds until one long tone sounds and the display clears to show an outline if the display area. Repeat to unlock control, and return display to the time of day, if any pad is touched while the control is locked, there will be no response from the microwave oven. hope this helps.
Mar 28, 2009 | Magic Chef MCM660A Microwave Oven
The fan starts up and runs on its own and we are cooking
That is a normal safety feature.
That's only covered in a very subtle note in the hood fan section of your owner's manual:
NOTE:If the temperature gets too hot around the
microwave oven, the fan in the vent hood will
automatically turn on at the HIGH setting to cool the
oven. It may stay on up to an hour. When this
occurs, the fan can not be turned off.
If for some reason you don't have your owner's manual, you can download it here.
Enter your model number as MV1610ST with no spaces.
You will need the free DJVU viewer to view or print your manual.
Dec 14, 2008 | Goldstar MV-1615 Microwave Oven
Fan and light constantly on
which fan? the exhaust fan or the control board cooling fan? the cooling fan is controlled by a thermostat just behind the control panel. it turns the fan to protect the board from overheating.
Feb 18, 2008 | GE JVM1440 Microwave Oven
Fan started running and will not stop when off button is pushed
Hi , the door lock switch are stuck./ the contact switch are not stick together need to replace new.
Jan 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
233 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
