Question about Ovens
I have a wall oven, a St George single oven. The
I have a wall oven, a St George single oven. The door has slid or lifted along its hinge so it wil not close properly. How do I refit/remove the door so that it will close?
  • 2 more comments
  • Anonymous Mar 15, 2014
    when clock comes on oven goes off
  • Anonymous Mar 20, 2014
    saint George oven
  • Anonymous Mar 25, 2014
    I have a DEO-9A Wall oven and need new hinges to top oven only as door does not close. Hoew difficult is it to renew both hinges
    I have a DEO-9A Wall oven and need to replace 2 hinges. How difficult is it to renew the hinges
  • 93 Answers
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Posted on Sep 12, 2009
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
HOW DO I REMOVE THE OVEN DOOR & HINGES FROM ST GEORGE UEOLAS ELECTRIC OVEN PLEASE
Most oven doors can be removed by opening door and pulling straight out. The hinges are attached to the oven frame not to the door. Some oven doors have screws that are attached to the hinges at the bottom of the door on the inside that need to be removed, then pull straight out.
May 16, 2016 | Ovens
Cannot put the oven door back on
Hi Elspeth:
Don't know what make or model you are dealing with, but from personal experience, here's what I dealt with.
- Oven door is mounted on spring loaded hinges. That's what keeps it in the closed position.
- To remove the door, it has to be fully opened, then lifted from close to the hinges, and slid out.
- To put the door back on, the hinges have to be in the "door open" position. Since they are spring loaded this can be tricky getting them into position.
- It's easier with a helper, one on each side....... slide the hinge legs into the slots. You'll need to lift the door slightly towards the closed position to allow the hinge legs to engage in the secure or latched position.
Hope this helps.
Cheers.
Dec 06, 2015 | Ovens
We have a 30 in prostyle electric double wall oven - the oven takes forever to preheat and the doors do not seal tightly when they are closed.
Hello- Many ovens use spring-loaded hinges to carry the weight of the door. Over time, these springs weaken or the hinge gets bent just enough to not fully close door. The door gasket can also become flat and stiff, compounding problem. Any small gap releases heated air, and oven will not heat up properly. Replacing the door springs should solve problem.- Thanks -Ed
Mar 14, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Need to get the door off - model number B7425b1600E
To remove door: Open oven door fully open. On the hinge there is a small metal tag that swivels up and fits over a small hook on the hinge. Do this on both sides of hinge, then gently close oven door whilst lifting upwards- door will lift off. Reverse procedure to refit.
Mar 10, 2010 | Fisher and Paykel Ovens
My oven door doesn't close completely. Is there a way to adjust the door?
Hi There
I found this for to read so you can fix your door.I hope this will help you.Let me know how it goes.
The oven door won't close If your oven door has gotten bent or warped (maybe you rested something heavy on it…), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up. If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Thank you for writing to fix ya.
Best Regards Richard
Dec 30, 2009 | Ovens
How do I attach the oven door back on to the stove? When I try to prop open the brackets, and reattach the brackets snap back closed. George V
Usually there is a hole that you open the hinge and put a nail in on each hinge to hold them open until you get the door in place.
Nov 21, 2009 | Maytag CWE4800A Electric Single Oven
How to remove door for whirlpool oven RBS305PDB2
open the door about 1/3 of the way and lift it off the hinge pins. it helps to have two people do this. when it is time to replace it, put the hinges in that 1/3 open position and slide the door back down on.
Oct 02, 2009 | Whirlpool RBS305PD Electric Single Oven
Ovens Logo
632 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
