Question about Amana Dryers
My Amana gas dryer is making a squealing sound. I took off the drum and belt and checked them. They seem OK. I started the motor with the belt and drum off and the squealing is coming from behind the blower wheel where it connects to the motor. Can I lubricate this or could it be the blower or motor that needs to be replaced?
    Sergeant:
  • 222 Answers
Usually there is hair wrapped around the blower wheel shaft try cleaning that if it still does it it may be the motor itself
Posted on Sep 12, 2009
Squealing dryer
Sounds like the drum bearings are going bad, or at the very least need lubrication. thats what your problem is.
Jan 25, 2008 | Estate TGDS740JQ Gas Dryer
How do I stop dryer from squealing
the squealing noise is most likely a loose drive belt , the drum is powered by a large belt to a motor , the belt and idler pulley are most likeslyin need of replacement
Dec 11, 2014 | Dryers
My Maytag Neptune gas dryer is making a very load squealing sound when in use. Is it possible that I need a new motor? I had a repair man come out and his answer was an entire new motor. The cost of the...
I do not believe the problem is with your motor.
I think it is your drum rollers in need of lubrication or replacement.
Replacing the drum rollers is a LOT CHEAPER than replacing a motor
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 23, 2010 | Maytag Dryers
The dryer heats, motor runs but drum doesnt turn.
Could be one of several things. The drum turns by motor and fan belt around the drum. The most common problem is that the fan belt is broken. Check to see that the drum is free and not bound up by frozen bearings. Also that nothing is jamming the drum. If everything seems to be ok --- you need to check the pulley on the motor shaft and be sure it is tight on the shaft . More than likely -- it is a broken belt. I hope this helped.
Dec 14, 2010 | Amana ALG443RAW Gas Dryer
Squealing noise
it sounds like your drum guides that go around your drum they may be worn now. or your bearing in the back of your drum
Jun 11, 2009 | Amana DLE330RAW Electric Dryer
Won't spin or start
Sounds like the screen/sock combo got the tub in a bind and the drum belt broke.
If you want to pursue replacing the belt, let me know.
Apr 30, 2009 | Amana LGA10 Dryer
HOTPOINT DRYER VTD00G REPLACED BELT BUT WONT SPIN
Most likely to be a faulty start capacitor.
This a round plastic cylinder adjacent to the motor.
This gives the motor a kick start.
Dec 02, 2008 | Amana ALG443RAW Gas Dryer
Dryers Logo
89 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
