Question about Garden
I have a craftman garden tractor which has a 24hp
I have a craftsman garden tractor which has a 24hp kohler engine. a lot of time, it has white smoke comes out when i start it up.
  • 10,865 Answers
You most likely have a head gasket that is leaking. At the end of the season you should call your dealer and have it repaired.
Posted on Sep 12, 2009
What would cause 19 horse kohler in cub cadet to belch white smoke
answered already look at charles beach answers mower belched white smoke
Sep 02, 2014 | Cub Cadet 42 in. 19 HP Kohler Courage...
Craftmans mover blade keeps hitting ground
Is the deck too low or one side lower than the other? Level the deck side to side, front should be a little lower than back (about 1/4 inch). check tires for correct air pressure. Make sure blades are balanced.
May 10, 2014 | Craftsman 42 in. Precision Cut Plus 24hp...
Craftsman tractor with 24HP kohler engine not letting fuel go from carburator to engine
see if there is power to the solenoid on the bottom of the carb if no power check the safety switch on the brake/clutch pedal if you have power see if its moving the plunger if its stuck try and clean it with carb cleaner
Apr 29, 2012 | Garden
I have a 2 year old Craftsman Professional Series 24hp, 42" lawn Tractor, PYT series. My problem is that it is very hard to start. Battery is fully charged, new sparkies, changed oil, Takes 4-5...
Mike I just found your post after answering another post. If you still need help I can help you but need to know your ENGINE model number. (Engine brand too please) What your describing is usually caused by valve seats that are caked with carbon. The puff of white smoke you see can be caused by valve stem seals or the piston oil rings. I would not be too concerned about the puff of smoke unless you really lose a lot of power. Often you can remove the cylinder head and use valve grinding compound to re-seat / clean the valve seats. Sadly you have to remove / unlatch the sprong keepers of the valves to do this. It isn't hard but without the first hand knowledge of how the spring keepers are installed it can be very frustrating. Again engine model number please and I can probably get youa link to an on-line service manual that you can use. Not sure why no one answered your question before but.. I am ready to help you now.
Thanks, Kelly
Dec 17, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
27 hp kohler v-twin ohv backfires, and @ times blows white or black smoke
SOUNDS LIKE IT HAS BAD GAS AND THE VALVES NEED RE SET YOU MAY WANT TO FLUSH YOUR FULE AND CLEAN OUT THE CARB LET ME KNOW IF THIS HELPS
Oct 08, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a craftman lawn tractor with a 15hp kohler engine. Engines starts and runs fine After mowing for a while and then shutting it off the engine will not restart until it cool off completly. Any...
See if there as any difference in compression when the engine is cold verses hot. Also check ignition spark when it is hot. Unit could be vapor locking because of heat. Carb float could be suspect.
Sep 14, 2009 | Craftsman Garden
Craftman Lawn mower continues to burn oil at a fast rate
Are you getting a lot of smoke? If so the oil is getting past the rings and burning.
Jun 23, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
