Question about Zanussi FJS1225W Front Load Washer
Zanussi err problem
Hi I've a Zanussi Fjs1225w washing machine, during the cycle the machine keeps flashing err but no code comes up, when you press the green pause button the beeping noise stops, has anyone got any ideas?
  • 2 more comments
  • mothermare Dec 13, 2007
    yes i have the same problem.. also get " fault E190 " flashing. any ideas yet?
  • ralphd Dec 28, 2007
    machine will not spin
  • patrickc Jan 06, 2008
    it turns out it was the main board needed replacing for me, thats the second time since we had this machine and along with other problems it developed we decided to buy a new one, much more cost effective (and not a zanussi)
  • Anonymous Mar 27, 2014
    It's not responding to anything but beeps and displaying "Err".
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
Fabric conditioner compartment will not empty when in cycle
FJS1225W Front Load Washer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Zanussi FJS1225W Front Load Washer
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Sep 07, 2009 | Zanussi FJS1225W Front Load Washer
Iz 161 w jet system washing machine
I have had a similar problem before, check that the hose outlet is not blocked, or that the drainage pipes are not blocked.
Jul 07, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
May 29, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi washer
Press "end of cycle" button to clear.........................
Jan 04, 2008 | Zanussi FJS1225W Front Load Washer
Washer whilst washing keeps flashing up with E90
Click on Zanussi (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Nov 06, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi jetsystem 1200 wahser dryer problem
You usually turn off your inlet valve after your washing is done. Well, if it keeps filling after u hv turned off, you have a problem with your inlet valve, which you should replace.
Oct 07, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
339 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
