Question about HP OfficeJet 6210 All-In-One InkJet Printer
PHONE OF THE HOOK WHEN HP6210 connected to Cablevsion cable
I just returned to cablevision fromVerizon FIOS and before leaving cable vision and while on Verizon phone the fax worked. However when I returned to cablevision I got connected throgh Motorola SBV5222 cable modem and everytime I connect HP6210 or similar HP5610 is shows as if the phone is off the hook. I disconnect the all in one I get the phone line is good. I can connect other phones and make calls. I also connected an old Epson fax phone and I can fax using it and it does not behave as HP. Could it be in HP setting or anything else? Do I need an inline filter??
  • gabesilberma Sep 12, 2009
    I have located the solution myself and it just took a little closer reading of the manual. I, not knowgly any better and thinking that it does not matter, connected a phone cable with 4 wires and the on line manual says it will only work with 2 wire phone cable connected to the printer. Wow I am did not know that this will make a difference. It worked but I am still puzzled why it will make a difference
  • 163 Answers
SOURCE: Fax shows an 'off-hook' status
pleaz check the hook sensor
Posted on Sep 16, 2007
leroyal
  • 2120 Answers
SOURCE: HP 7280 fax interrupts phone calls
Set the fax to MANUAL MODE, you will then have tp press START to receive a fax.
Posted on Dec 21, 2008
  • 103 Answers
SOURCE: machine shows "phone off hook"
Hi there
check where your phone cale goes into the machine you will proberbly find two sockets one marked phone and one marked line the phone line needs to go into the one marked line and a phone handset in the one marked phone if this is correct try ringing yor line that the fax is plugged into see if you get a ring or engaged tone if you are getting engaged unplug the fax and try again if this now works the chance is that the modem board in your fax has failed and will require replaceing
Regards AL "alstech"
Posted on May 26, 2009
SOURCE: Hp all in one 5610 wont receive fax and phone
geeting error 322 masage when faxing
Posted on Jul 17, 2009
SOURCE: my HP Officejet 5610 All-in One is not receiving
do you have cable service
Posted on Feb 26, 2010
Yamaha rx-v367 and internet tv audio
try connecting the hdmi out from cable box to your tv hdmi input, and leave the hdmi out from tv to the reciever where it is, leaving reciever selected to 'TV' and yes, a sub matters (it is not part of your problem but you need the bass a sub provides)
Mar 05, 2013 | Yamaha RXV367 Receiver
I have a dell 2400 desktop computer. I recently got FIOS and they hooked my wife's computer to their router with an ethernet cable. Can I also hook my dell up the same way?
Depends on the hardware. Is it a router or modem? Does is have extra ports in the back,
Router with extra ports, just connect new device with wire or even wireless if it has wireless.
Modem, most likey you have to buy a router.
Dec 28, 2012 | Dell Dimension 2400 PC Desktop
My internet is greatly reduced with Belkin N1 vision wireless (before the hook-up it was 15mbps now only 5mbps), I have tested by hooking directly from the modem to the computer and got 15mbps. Before N1,...
When you only get 5 mbps are you connecting to the new router wirelessly or via the ethernet cable? If it is wirelessly then try connecting with an ethernet cable and see if you still get 5 mbps. If so then try resetting the router (the procedures for this will be explained in the manual) and re-test. Wireless connections can slow down due to obstacles such as thick walls or other obstacles of that type. If all else fails return the unit and try another.
Mar 08, 2011 | Belkin N1 Vision Wireless Router
I have a cablevision box with a set of red, green and blue wires and another set of red and white wires. How do I hook the cable to tv to get cable? The colors on the front and back of the Mickey tv are...
hi. The colored cord you described are for high definition, there should also be some jacks on the back of the cablevision box that say "video out" "left""right"
Find those, and the video out is the yellow in jack on Mickey, and the Left is the white jack on Mickey
If you can't find those, then use the cable tv out from the box to hook it up to your tv.
This is all that is needed to hook up really, just the coax cable from the box to Mickey.
I know Mickey has a antenna cable jack on the back.
Just run a cable from the box to mickey, put Mickey on channel 3, or 4, depending on what the setting is on the box, and you should be good to go!
Feb 08, 2011 | Disney DT1300-C 13" TV
I have a RCA Thomson DHG 535-2 without the disk for the installation and the ethernet wont help everything is hooked up etherent/cable to tv power yes... and that's about ti all im really missing is the...
Thomson Cable modem has an ethernet connection...
The ethernet connection goes to your computer via a standard Cat5e patch cable. There is no USB that I know of...
Cablevision wire goes to the modem. It should be the first device on the cablevision wire. If you need a splitter, it needs to be a GOOD one, connected DIRECTLY to the incoming Cablevision wire as it enters the house. Use good copper wire.
Order of events:
Connect the cablevision wire to the Modem.
Connect the Ethernet cable to the computer and the modem.
Power on the cable modem.
Right click the network Icon near the clock and click 'repair' (Or reboot the computer)
Apply for and get an account for cable Internet from your Cable company.
After a few days, cable Internet should work.
Apr 16, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
Recording on a STB and being able to watch a DIFF channel.
It is possible to record a channel and watch a second channel. If your cable vision has digital-only signals, you will need a Digital tuner or a second cable box.
If your cable has conventional channels still, you can buy a splitter and run the cablevision to the TV and the CableBox at the same time.
Switch to the TV tuner, you see cable.
Switch to the recorder (connected to the CableBox) and you see what you can record.
Mar 28, 2010 | Televison & Video
How do i hook up my 16-454 to my verizon fios cable?
I am not sure what a FIOS use, but I was able to split my cable connection and was connect my regular TV AND portable tv with the cable.
IN YOUR CASE:
Look at your fios set up box, behind the box, there should be something that would say "TO TV" or "VIDEO OUT" or "TO TV/VCR"
Usually, the cable coming out from there goes to your regular TV. So instead of your regular TV, you can connect that with your portable TV.
AS FOR MY CASE (Having 2 tv's),
1. I removed the cable that is connected to the wall (RF IN or From WALL or CABLE IN).
2. I hooked that end to the "IN" part of a 3 way splitter
3. I bought a short cable and connected one end to the Cable Box and the other end to the OUT of the splitter
4. I bought a longer cable and connected one end to the portable TV and the other end to the OUT of the splitter.
5. Then I turned on the TV and pressed MENU
6. I clicked the right arrow until I see ANTENNA. I pressed the down button to choose CATV instead of AIR.
7, I did auto scanning.
My portable TV now has the basic channel while the big TV (since it is connected to the cable box) has the added digital channels. Nevertheless, it is great to have both so when I want to sleep, my hubby can just use the small tv
Jul 02, 2009 | Accurian 16-454 Television
Can we operate HP6210 as a FAX without a computer hook up?
Yes acutally you just need to plug it into an analog phone line and it should work.
May 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
64 people viewed this question
Seeker5211
Seeker5211
