Question about Refrigerators
Admrial LTF2112AR fridge not cooling
Over the past couple of weeks I have noticed the temperature increasing in the fridge. Got home today and it was actually room temp in the fridge but freezer is working fine ..... anyone have any ideas ?
  • 4,070 Answers
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Posted on Sep 12, 2009
Temperature controls seem to be playing up and then stopped completely
Try resetting system. Unplug for 10 min. Then plug back in. Set all temps. 36 ref. 0 fre.
Jun 18, 2017 | Refrigerators
Fisher paykel e381t
It is probably no more expensive than a CONTROL BOARD...
POSSIBLY as cheap as a door switch...
It is sensing a DOOR ALARM... and quite reasonably
stopping ... and alarming.
You need to find the PIZZA box, poor door alignment
or FAULTY circuitry that is causing the ALARM.
ELSE
Contact the maker for support
(on your back panel... or by reading your Owners Manual).
Like (example)...
Fisher Paykel E331T Installation Instructions And User Manual Page 44
Hope this helps
Carnac the Magnificent
Jul 28, 2017 | Fisher Refrigerators
Frost and freezing in the fridge
its warm damp air getting into the fridge causing the frosting if it builds up to much the fridge will find it hard to keep things coold down and you will need to "de-frost" it,,to do this rap all your food up in a blanket to keep it cool them switch off the fridge and put a tub of boiling water in side it leave the door open the frost will soon fall away,,wip out the fridge with "by carb" and switch it back on for an hour or so before you put your cold food back in it
Jun 29, 2010 | Liebherr KELB 2840 Premium biofresh...
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
Viking Refrigerator stopped cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 12, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
On top freezer works fine, fridge compartment below is not cold.
turn the dual temperature switch to warmer for the fridge to cool down.
Apr 04, 2009 | Refrigerators
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Nov 23, 2007 | Fisher and Paykel Active Smart E522B...
The refrigerator side is not cooling.
ALMOST DEFINATELY YOU WILL HAVE AN ELECTRONIC CONTROLLED AUGER(MOTOR)CONTROLLING THE AMOUNT OF CHILL ENTERING THE FRIDGE COMPARTMENT. IF YOU SET THE FRIDGE TO MINIMUM AND LISTEN CAREFULLY, THERE SHOULD BE A SOUND INDICATING THE AUGER IS WORKING.( OPENING AND CLOSING THE FLAP). SET TEMP. TO MAX AND LISTEN. IF NOTHING, IT COULS BE A DEFECTIVE MOTOR OR FAULTY THERMISTOR(TEMP. PROBE).
Aug 08, 2007 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
208 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
