Not able to install printer driver getting printer spool error message
  • steve johnson May 11, 2010
    what is the error message ?
    President:
  • 987 Answers
Goto Start>Run>Type services.msc ...
then select print spooler service and start it if already started ..just restart it ..then try to install driver
Posted on Sep 12, 2009
I am trying to print and keep getting a spooling message
I had the same problem and basically you need to uninstall the driver, then reinstall it again. By the way, Kodak no longer makes printers because they keep breaking due to performance problems. I had two of them and had to return the original four times to Kodak for repair.
If you cannot fix the problem, look into a new printer.
Dec 10, 2013 | Kodak ESP 2170 All-In-One InkJet Printer
RunDLLEntry@16
LXCGtime.dll is a module installed with the spooling drivers for Lexmark printers. This is required for your printer to work properly and should not be disabled. You may need to re-install the Lexmark printer driver hope this helps
Mar 25, 2010 | HP Pavilion dv6000z Notebook
My Printshop 15 does not operate properly, and i am
Not sure what your exact message is but on their support site it listed this:
Invalid Page Fault in Module ADBOOK.EXE Description Solution While trying to print or preview in the Ultimate Mail Manager Address Book (included with The Print Shop® 15), the message "ADBOOK caused an invalid page fault in module ADBOOK.EXE" appears. This error is usually the result of an outdated or incompatible printer driver. Checking for proper settings or updating the printer driver or both can help to resolve the issue. The remainder of this technical note describes how to proceed. Follow the procedure below to help resolve the issue.
  1. Close all programs and return to the desktop.
  2. Click Start, choose Settings and select Printers.
  3. Right-click the icon that represents the printer being used and verify that Set as Default is checked.
  4. Choose Properties from the menu that appears. The printer Properties window will open.
  5. Click the Details tab.
  6. Click the Spool Settings button.
  7. Change the Spool Data Format to RAW.
  8. Click Apply and click OK.
  9. Close the Printers window.
  10. Open The Print Shop® 15 and Ultimate Mail Manager and try to print again.
NOTE: If the issue continues, contact the printer manufacturer and request an updated printer driver and directions regarding the installation of the updated printer driver. Typically, an updated driver can be obtained from the manufacturer's Web site.
If the error reappears after downloading and installing the new printer driver, continue with the following procedure.
Install an Emulation Driver
  1. Install a suitable emulation driver. For help identifying and installing a suitable emulation, contact the printer manufacturer.
  2. After the emulation driver has been installed, launch and use the program. The issue should be resolved.
NOTE: For some printer models, it may be necessary to switch back to the original printer driver when using a desired application in order to gain full functionality of the printer.
Dec 06, 2009 | Broderbund The Print Shop Pro Publisher 15...
How can i installed my printer hp deskjet 1360,
if you have driver cd with you for the printer put the cd and run the set up before start the setup connect the printer to PC then start the installation ....... and fallow the instraction .... if you don't have the driver goes through this and download it
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1119343&prodTypeId=18972&prodSeriesId=1119342&swLang=8&taskId=135&swEnvOID=228#1130
if you getting any print spool error restart the print spooler service
start..>run..>type services.msc ...> it will open the services find the print spool service and start it ........
Nov 27, 2009 | HP DeskJet 656 Thermal Printer
Printer error messsage
attempt to clear the print spool and set the its settings to print directly to the printer. Do a test print, then enable print spooling again. If the same thing happens, uninstall and reinstall the latest printer driver
Jan 16, 2009 | HP LaserJet 4350 Printer
Lxczpswx.exe error when booting up windows
Try this:
Click on START, click on RUN
A small window opens, delete anything that may be typed in it and then type this -
regsvr32 /u c:/windows/system32/spool/drivers/w32x86/3/lxczPSWX.EXE
click OK
Oct 30, 2008 | Lexmark X1270 All-In-One InkJet Printer
When ever I reboot,turn on or bring my pc out of hibernation I get the below error message from my printer:
Uninstall the printer driver...and reinstall it...else the you have to reinstall the OS
PLEASE don't forget to RATE ME (FIXYA) for my help..........
Aug 14, 2008 | Lexmark X2470 All-In-One InkJet Printer
Printer Error
check all drivers first........
if it dont work............try to print any matter........
if it work then main matter u r trying to print may be in not a printer supported format
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 25, 2007 | Computers & Internet
48 people viewed this question
k24674
jasbo
jasbo
