Question about GE Washing Machines
Timer control won't ingage. Took timer knob off and it seems to be ok but it will not ingage with the teeth on the part below it. It just goes around. Disk that has the pointer on it seems to fit properly and engages intermitently. What is the problem? Everything else seems to work. Can't afford to call a repairman so pls help.
  • 93 Answers
A pin thru the timer shaft can break, or the plastic teeth it engages in can be stripped.
It is not difficult to repair if you have the parts, but you can only get these from another timer- maker will not supply parts.
To take timer apart.
Take it out of the machine.
You will see two twisted metal tabs on the back and one on the front.
Carefully straighten the tabs and the timer will come apart as FRONT, BACK, CAM ROTOR
Gently remove the shaft and you will see what part has failed.-- replace.
Be very careful with reassembly not to bend the contact fingers.
Posted on Sep 12, 2009
I have a timer control problem with a LSR5233EQ0. I need to press down on the timer knob to keep the machine working. It will agitate but with stop when it goes to spin.
Possible that the timer contacts are not giving connectivity when it moves forward into the cycle and so there is no control to the motor drive causing it act irregularly.
The suspect seems to be the timer module.
Jul 29, 2012 | Washing Machines
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
The control knob is stripped & I removed that; also found that the plastic part with teeth that the control knob operates is also stripped. Where can I find both parts and what is involved in...
Used to be that you could buy the ratcheting coupler piece for 5 or 10 bucks for the old GE machines. Alas, no more. The newer GE timer must be replaced if the teeth are stripped.
Be careful not to damage the indicator dial when doing this repair as it is about $20 for a round piece of plastic and a tiny steel clip. Pry this off using opposite points of the dial (grab it at the 9 o'clock and the three o'clock positions with as many fingers as possible) and pull gently so as not to set up any fractures in the dial's hub.
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Washer-Parts/Model-WCSR2090D1WW/0432/0153200/G0503026/00001?blt=06&prst=&shdMod=
Unplug machine, remove knobs, end panels. Remove remaining screws that hold the control panel and tilt forward. Removing the fascia will reveal the screws that hold the timer on.
Sears PartsDirect wants about $80 for the timer.
Good luck from Detroit, MI.
Jul 11, 2011 | General Electric WCSR2090D Top Load Washer
Model: 110.29822800 Cycle Control knob seems loose. When turn knob clockwise and pull knob, it seems like out of position. For example, I set at Normal, rinse and pull knob. It rinse a minute or two and...
Could be one of two things. The knob or the timer. Both knobs and the timer through sears parts direct are under 100 probably with shipping. If the knob that you pull out and push in does not feel sloppy when you turn it then i would guess timer is faulty.
Feb 27, 2011 | Kenmore 24032\24036 Top Load Washer
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
GE WASHER MODEL #WBSR3140G0WW: TEETH ON CONTROL
I suspect that a mounting tab has broken off the timer. Take the four torx head screws off the back edge of the top of the washer and open up the backsplash to confirm this. I manufacture a make shift Z shaped metal part to hold the timer in place without having to replace the timer.
Mar 25, 2010 | General Electric WBSR3140GWW Top Load...
Control knob hangs
Timer has small gear pull panel off and see if gears are stripped in one spot meaning no teeth on the gears
Aug 24, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Washer control knob just spins
The knob is prob stripped, very common for this washer.
Get it off and look at the teeth. To remove the knob you need a pair of surgical pliers. Reach behind the knob and yank the retaining clip out. If the teeth are smooth you need to replace the knob. Oil the timer so it will be easier to turn by the way. To put the new knob you simply slide it in place with the clip on it. So easy you won't believe it.
Feb 03, 2009 | GE WBSR3140DW Top Load Washer
Control knob will not turn to desired setting
the timer knob has a clip that will allow you to remove the knob from the timer. it is between the knob and the dial. what happens is the knob has gear like teeth that will become stripped out.it is easy to replace but alittle hard to remove. you need to get a small screwdriver and go behind the knob, pull on it alittle and you will see the clip, then use the screwdriver to push the clip out of the knob, then the knob will pull of and you can replace it.
Dec 28, 2008 | GE WJRR4170E Top Load Washer
Ge timer on washer is broken
If it no longer clicks, the timer assembly will need to be replaced. If just the knob broke off, the timer should be good.
Mar 16, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
43 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
