23HLV86/DVD Pink vertical line 1/4 way in from
23HLV86/DVD Pink vertical line 1/4 way in from the left side.....anyone have an idea which board could be in need of changing?
  • 668 Answers
If this is a LCD Flat Panel TV, the LCD Panel it self would probly need to be replaced.
Skyassoc
Posted on Sep 12, 2009
I have an LG 2009 60ps60 plasma TV with multi color vertical lines on the left side of screen. Is there a board I can change to correct this problem??
1. Identify the TCON board.
2. Reset the Left side ribbon cables on the T-CON board
3. Replace CON board if you find a spare
Apr 13, 2016 | LG Televison & Video
Blue Lines streaking in from left side of 70 inch Sony HD TV
okay my friend your tv vertical circuit is begining to get faulty you could be having some bad caps or the vertical ic is defected have a tech check your tv for repairs.if you are not a tech you cannot repair the set by your self.good luck.
Jun 25, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
LG DU42PX12X - red and pink vertical lines.
I know this post is old,
But I had the same problem.
I was able to fix it.
Heres a write up I did on the "How To".
I added pictures and diagrams too.
http://jasonkoller.blogspot.com/2011/02/lg-du-42px12x-plasma-tv-fix.html
Jul 22, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Multiple reddish pink vertical lines going from
take the top cover off and look for the 3 lcd ribbon cables plugged into thr main board. it is a pain in the ****, but the cable must be completely seated into the things on the main board. there should be little brown tabs on the connectors on the main board that you flip up or down, then make sure all lcd cable are pushed all the way in.
May 14, 2010 | ASK Proxima DP6860 Plus Multimedia...
Hi
We can check if the problem is on the hardware(projector) itself or if from source(device connected to projector) try to turn on projector without connecting any other devices to it. If you can still see the pink line- try to remove bulb and reinstall it. If all fails and pink line still visible, there is a problem with projector. If no line is present- check settings and change input signals.
Hope this helps
Mar 26, 2010 | ASK Proxima DP6860 Plus Multimedia...
I have a VIZIO P50HDTV1QA DLP television and it
It sounds like the Color Wheel assembly has gone bad.Call a good TV Tech and explain the symptoms and he should be able to give you a ballpark estimate ($325)
Jul 29, 2009 | Televison & Video
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Vertical lines on left half of screen
The problem is the driver tabs that go from the panel controller board to the panel itself.
This is normally a fatal failure since having it repaired is extremely expensive.
Mar 17, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Vertical lines in picture
If your satellite is in the component jack and does not have the lines, you have a bad doubler or 2HD board. These boards are located in the metal container on the left side of the tv (left as in when you are looking at the back of the tv).
Mar 31, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
