Question about Car Audio & Video
I have installed a used ignition switch in a 97 Pontiac Grand Am, and it won't crank. Also, the "theft protection" light is coming on.
  • 1,305 Answers
Try disconnecting the battery and waiting for an hour in order to reset. Recheck. Hope that helps.
K
Posted on Sep 12, 2009
It got tow and the key was not in it,so now the aniti thife lock is on and will not come off may you may know what to try..master key is gone..pont grand am 1996
YOU HAVE TO GO TO DEALERSHIP.THEY WILL HAVE TO GET YOU REPLACEMENT KEYS USING IGNITION LOCK NUMBER OR USING ORIGINAL PATTERN.WHEN YOU GET THE NEW KEY.JUST PUT NEW KEY IN THE IGNITION SWITCH.TURN IGNITION SWITCH TO THE ON POSITION FOR 10 MINUTES UNTIL THEFT SECURITY LIGHT TURN OFF OR DISAPPEAR.THEN TURN OFF IGNITION SWITCH WAIT 10 SECONDS TRY STARTING THE VECHICLE IF THEFT LIGHT STILL ON.YOU WILL NEED DEALERSHIP TO USE A DIAGNOSTIC EQUIPMENT TO CODE SCAN AND ERASE THEFT SECURITY CODE.
May 01, 2011 | Pontiac Grand Am Cars & Trucks
I start my car but it immediatly shuts off and the theft sys light flashes could this light be the reason?
the ignition swith reads the key chip when key is turned, this is a common problem,the ignition switch will need to be replaced, after replacing the swith reprograming will be needed, to program you will need a battery charger to keep battery from going dead, after installing new switch,turn charger on, turn key to crank then release key leaving ignition on, you will see the dash lights, leave key on for about 15-20 min, until you see theft light go out, if light doesnt go out then repeat process,crank for 2 sec, then leave key on 15-20 mins until security/theft light goes out, hope this helps.
May 09, 2010 | 1997 Pontiac Grand Am
97 grand am 3100 wont start check eng lite dont
if you havn't replaced the fuel pump yet that should do the problem
Oct 20, 2009 | 1997 Pontiac Grand Am
97 grand am wont start
It sounds as if you still have a problem with the anti theft system. Possible loose switch wiring in the dash or it was programmed and cycled incorrectly.
Aug 30, 2009 | 2005 Pontiac Grand Prix
1996 Pontiac Grand AM
Try this first, it takes about 30 min to do. 30-Minute Learn Procedure 1. Turn ON the ignition, with the engine OFF. 2. Attempt to start the engine, then release the key to ON; the vehicle will not start. 3. Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF. 4. Turn OFF the ignition switch, and wait 5 seconds. 5. Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK Important: Turn the Ignition Switch OFF. The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. 6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password. 7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles. Without a scan tool you may have momentary starter interruptions while history clears itself. Good luck and hope this helps, keep me posted, be glad to help
Jun 14, 2009 | 1996 Pontiac Grand Am
Diagram on a pontiac grand prix
I have 07 Pontiac Grand Prix, the wrong key was inserted into the ignition the other day. Now when I try to use the correct key it will not insert completly in the ignition, goes in until last 1/4in of key. Im stuck, I bought the new lock cylinder but how do I get the old one out? I cant get the key to insert all the way so I cant get it to the "On" position, it will not turn at all. The key that was inserted in error is whole and nothing is missing it seems like there is something stuck. Any help would be appreciated...
Sep 09, 2008 | 2000 Pontiac Grand Prix
1997 pontiac won't stay on
i had the same prob. w my 97 grand am. i bought a new ignition switch and installed it...after installing you have to reset the theft system. all you have to do to reset is turn the key far enough for it to bump the motor over then leave the key in the run position for about ten to twenty minutes...might hook bat. to charger cause if it dies in process you have to start all over...the theft light will either blink then stay on or go out completly....
Jul 10, 2008 | 1997 Pontiac Grand Am
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
