I have a RCA D52W19b TV when I turn it on it blinks three times then shuts off I replaced the CP114 and the CP150 CAPACITORS STILL SAME PROBLEM PLEASE HELP IF YOU CAN SINCERELY gary bryant
  • 8,617 Answers
Try replacing the flyback . Its flyback number 259296 and its available at the following link with detailed instructions.
www.tvrepairworld.com
Posted on Sep 13, 2009
Testimonial: "Thanks for the info I got my flyback at jim@suburban-elect.com; it is a lot cheaper I paid 31.90 including shipping"
I have a 52" rear projection TV. D52w19b. Green
Make sure you resolder the flyback and recheck any RCA fuses that may be blown - they are usually near the flyback. If this does not help check the site www.tvrepairkits.com for repair kits or tips for your projection tv model.
Apr 27, 2013 | Televison & Video
Describe your D52W20 52 in. Rear Projection HDTV-Ready Television Problem the tv will not turn on the power light will blink three times then shut off
That could be caused by the CP150, CP120 and CP114 capacitors on the deflection board. Very famous issue. You can get the RCA repair kit by that same name from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Aug 27, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
When we turn the tv on in blinks the green light 3 times and never turns on. what is wrong with it?
sounds like the cP150, CP120 and CP114 capacitors need replacement. You can get the CP150, CP120 and CP114 repair kit from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Feb 26, 2011 | RCA R52WH73 Projection Television
I have a 52 inch RCA vt when you hit the power button it blinks 3 time but the tv wont come on its a modle D52W19B
replace the CP150, CP120 and CP114 capacitors. You can get the repair kit by the same name from www.tvrepairworld.com which contains the caps and the CD with instructions.
Jul 14, 2010 | RCA Televison & Video
Rca hd52w59 tv. power light blinks three times in
Thats usually caused by the CP150, CP114 and CP120 capacitors which will need replacement. You can get that repair kit at www.tvrepairworld.com and the kit contains the CD with instructions for the repair.
Dec 14, 2009 | Televison & Video
RCA d52w25 52 inch blinks 3 times off...turns on...off
Most likely Capacitors cp150, CP120 and CP114 need replacement. You can get the repair kit at www.tvrepairworld.com under the RCA reapair kits catagory bottom of the page. The kit contains the capacitors and detailed instructions
Sep 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV will not turn on
Replace the CP150 CP120 and CP114 capacitors. You can get the repair kit for your RCA at the following link www.tvrepairworld.com The kit contains the capacitors and CD with detailed instructions
Sep 05, 2009 | RCA D52W19 52" Rear Projection Television
Rca D52W19
I would try replacing CP150 , CP114 and also CP120 as those three capacitors have been known too fail which will prevent the set from powering up.
Jan 28, 2009 | RCA D52W19 52" Rear Projection Television
Power ligt blinks twice no high voltage
CK capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is bad so replace all 3 caps.2200uf 16v and two 220uf 35v
Jan 16, 2009 | RCA D52W23 52" HDTV CRT TV
RCA 52 in tv
ON Deflection board there is 3 capacitors that most of the time will cause set not to startup cp150-cp114-cp120. values 2200uf 16v, two 220uf 35v, you buy caps at Radio Shack.
Dec 28, 2008 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
220 people viewed this question
Top Televison & Video Experts
