Question about Kirby Heritage II Vacuum
My Vacuumm kirby hertiage made a funny noise and started to smoke and doesn't work.
  • pmbrown1 Sep 12, 2009
    I was using the hose at time and the belt is not on when using the hose.
    The bar dosen't spin. so if smoke from my motor how do i replace it.
    Sergeant:
    Champion:
  • 214 Answers
Remove the cover and change the belt it may have got a rock stuck in the beater bar(brush)
Posted on Sep 12, 2009
  • tom wright
    tom wright Sep 12, 2009
    On some vacuums the bar spins regardles if yopu are using the hose or not cheak and see if it still spins while you use the hose.If it is not your belt it may be your motor that you seen smoke from good luck hope i helped
Kirby is smoking?
Send it back
It smokes & has no manual
You don't want either situation
It is defective,obviously
May 12, 2014 | Kirby Vacuums
Where does the fan belt go?
Hi There,
The belt on your Kirby Hertiage is put on almost exactly like the video below. The only difference on your model is that the brush actually rests in the bottom plate itself rather then the bell housing like the generation.
You can follow the same step by step instructions as the Generation in the video below, just put the belt around the brush, and put the brush into the bottom plate. Then put the bottom plate with the brush inserted, and the belt wrapped around the brush loose in the middle, back into the fan housing. Then turn the square shaped belt pulley on the font of the bell housing to the red setting. After the belt has been turned to OFF, then you may put the front bell housing back onto the vacuum cleaner, and after securing it onto the vacuum, now turn the belt pulley in the front back to BELT ON position.
The video will help you tremendously understand where and how the belt works on your Kirby. Here it is:
If you have any questions, or need help putting the belt on your Kirby, please feel free to use the comment section here on the Fixya repair page, and I'll be more then happy to answer all of your follow up questions.
If this was helpful to you, please be so kind and rate my repair helpful, or leave me feedback. This is really appreciated by Fixya repair professionals, and is the main reason that repair experts continue to leave free repair support, rather then just answering the premium questions that customers pay for. Please work the system Fixya has put in place, it's greatly appreciated.
Thanks,
Chris Jones
GoVacuum.com
May 01, 2010 | Kirby Heritage II Vacuum
Kirby turns on with hose attachement but not with head attachment
Front of the unit, black switch that is pressed by this plastic protrusion from hose coupling has two parts. It is because ANY generation Kirby has speeds - HIGH for vacuuming with hose and LOW for using it with nozzle.
Looks like the switch went bad (Switch HERE)
We have instructions for replacing it too.
The "funny noise" with hose throws me off a bit though. Check if there is nothing in the hose (put a nickle through it).
Good Luck
May 29, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Why does my Hertiage II vacuum seem to be getting no power although it is plugged into the electrical socket? Does the vacuum have a motor that might br blown?
Check to see if there are any breaks in the cord, like any of the insulation missing.
Also unplug it and feel along the cord for any unusual lumps.
Feb 27, 2009 | Kirby Heritage II Vacuum
Motor problem
First six pictures HERE will let you know how to remove shell to see the motor. I would not recommend starting it before you get the screw out (you will need to remove 5 more screws from the front f the unit to get the fan case off). The fan case is glued so you may need to use screw driver and pray the fan case of the unit. If fan is damaged - remove it from Kirby as damaged fan is out of balance and Kirby will vibrate like crazy. Shaft has opposite thread so you have to turn it CLOCKWISE.
If the fan does not come off easily you may have to remove this part and access the rear of the motor where you can use a wrench to hold the armature (you will see where you can hold it right behind the commutator. Removing slide bracket assembly memorize where the wires are plugged in and how it is engaged with the transmission.
God Luck
Rocky
Nov 10, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Sentria
sounds like the motor burned up. not sure if travel adapters will handle a large load like a motor, around 8 or amps. power needs in US are 110 volts ac, 60 hertz.
I believe UK is 220 volts and 50 hertz.
usually when a vac is brought to europe you must change motor.
Jun 13, 2008 | Kirby Vacuums
Vacuums Logo
79 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
