Question about Car Audio & Video
Okay about my car radio... when i turn my
Okay about my car radio... when i turn my radio on without my car being on it kills my battery all the way. i dont even have a sub or amp or nothing yet but i will so i rele wanna knw how to fix this problem. if u can help i wuld rele aprecite it.
  • 1,305 Answers
There's a good chance that your car battery is getting old. Car batts are good for about 3 years and then they'll work but can drain the battery with accessories left on when the car is not running to recharge the battery.
Have the battery checked... it may be time for a new one.
Posted on Sep 12, 2009
Go to turn the car on and all lights/ radio comes on but car makes a sound like drill? Radio has reset and car will not start
have a load test done on the battery as it s probably failed.. cold weather kills batteries.
Jan 26, 2015 | Cars & Trucks
Motor wont turn over
CHECK BATTERY VOLTS SHOULD BE 12.6 VOLTS MAKE SURE BATTERY CABLES AND BATTERY POST CLEAN FROM CORROSSION.MAKE SURE BATTERY CABLE TIGHT.IF ALL IS GOOD REMOVE STARTER WITH SOLENOID AND HAVE IT BENCH TESTED AT ANY AUTO PARTS STORES.IF STARTER OKAY. STARTER FUSE AND RELAY OKAY POWER IS GETTING TO STARTER. YOU COULD HAVE FAULT IN THE THEFT SECURITY SYSTEM.TRY TURNING ENGINE WITH A WRENCH TO MAKE ENGINE NOT LOCK UP. WARNING TO KEEP FROM LOCKING OUT RADIO TURN OFF RADIO FIRST BEFORE REMOVING NEGATIVE BATTERY CABLE.
Aug 30, 2011 | 1997 Toyota Tercel
I have a 2001 ford expediton 4.6 4wd..2 days ago I went to turn off my car and the radio and that beeping sound when the key is in the ignition when the door is open stayed on and wouldnt go off. I turned...
Not the Key but the ignition itself. Replace teh ignition module where the key is inserted to start the vehicle and that should resolve the issue.
Jul 11, 2011 | 2001 Ford Expedition
Battery keeps draining on 2010 Mazda 3 Grand Touring. Over a year ago, it turned out that a rear speaker was never turning off in the car. They fixed that issue. We are now having the same kind of...
Had a truck that kept killing battery and we unplugged the air conditioner control panel and no more dead battery. Don't know if will be helpful but worth a try.
Jun 27, 2011 | 2010 Mazda Tribute
My battery died, husband replaced it. Everything
some cars have a radio theft system that requires a code be enter to make the radio work if it is totally without power ( as if some one removed it from the car) you might want to call ford and see if your car has this system in it.
Apr 08, 2010 | 2006 Ford Explorer
What batteries(AAA) can i best use for midland LXT322 two-way rad
i need a manual for a lxt 322 2 way radio and it just had AAA batteries in it is that okay?
May 08, 2009 | Midland LXT310 2-Way Radio
I have an issue.. my battery died yesterday the guy who jumped my car messed up and attached the jumper cables wrong on his battery. Now my kenwood excelon ddx 7015 wont turn on at all do you think it is...
Hello Melissa,
The first thing I would check is if your fuse is okay. If your fuse is blown replace and try to turn on the radio. If the fuse is good have the radio taken out and have it bench tested. take the power wire and the memory wire put them together and apply power to them then take the black wire and connect it to ground if the radio turns on then its okay and he fried something else. If the radio doesn't turn on then chances are that he fried it.
You can use a car battery to test your radio or a portable boost jumper.
Hope this helps you.
Dec 03, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
