Question about LG Dishwashers
After i start my l g dishwasher it stops and flashes l e on the start button , and the water wont drain
  • 423 Answers
The LE error is saying that water is "leaking" out of the dishwasher before it is being intentionally pumped out. If you have checked underneath the unit for a real leak, then 99% of the time, your problem is related to a law of physics.
Follow the drain hose from underneath the dishwasher over to where it connects to the drain (normally the disposal) I bet you will find that the dishwasher is connected directly to that drain and not connected through an air gap. The hose is probably routed along the floor with no high point.
The drain hose must have a high point in it somewhere in the run so that a natural siphon does not get created and "pulls" the water out of the dishwasher while it is running.
Best way to fix it is to install a dishwasher air gap (almost free at any real hardware store) but you can also lift the hose and attach it somewhere to (under) the counter. That will prevent the LE error.
Posted on Sep 12, 2009
Fisher and Paykel Nautilus Dishwasher wont advance to take water in .
The problem could be with flood switch at base of dishwasher. Press the float to check if it springs back. Otherwise switch under it is faulty.
Jan 19, 2013 | Fisher and Paykel Dishwashers
Wash cycle does not start. I push the normal wash (or any other cycle) button and a tiny amount of water flows. If I leave it alone, eventually, several lights start flashing. I have tried pressing the...
Either the hose is clogged at the entry point to the dishwasher or the solenoid vlave is bad...
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Dec 21, 2010 | Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Green clean light wont stop blinking unable to use dishwasher . It is an energy saver. the drain button works ..and when you push start the light comes on but will not run for cleaning
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 19, 2010 | Kenmore 16602 / 16604 / 16609 Built-in...
Start light flashing wont start cycle, what does it mean
count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
Aug 06, 2009 | Whirlpool Dishwashers
Whirlpool dishwasher ADP905
Depress start button till start light goes out. Close door, drain pump should run for a while. Wait for end of program, rer-try a new program start. This process is re-setting memory.If this fails to sort problem then start checking components, ie: fill valve water on? heaters open circuit/down to earth, drain pump, is it emptying, wash pump.
Jul 31, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
L63 Salt light is flashing
goes for short time and 2 ljghts flash the red salt light wont go on
May 16, 2008 | Ariston Technologies L63 Free-Standing...
Whirlpool dishwasher adp550
f4 is a drain error, machine is still sesing water has not pumped out after 4 minutes of draining
1st check and see if water is still in bottom of machine if so check for blockeges under sink where drain hose cnnects to drain pipe.
if water has drained out you may have an water sensor fault or worst case an electronic control board fault
to reset machine hold the start button in for at least 3 seconds and it should do a drain and stop
Feb 19, 2008 | Dishwashers
Dishwashers Logo
135 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
