Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WM20
I have changed the brushes on my machine because there was no drum movement at all, that has not solved the problem, any ideas?
  • 3 Answers
You said you have changed your brushes and the machine did'nt
work, but i dont know why you have changed the brushes, may be the brushes were worn, but the first thing for the a machine to work would be the door switches.You will also have to change your door inter-lock to make your drum move or the machine will not work at a tall.I hope you find this information use full.
Posted on Dec 16, 2007
  • 139 Answers
Check the motor wiring harness
Posted on Dec 11, 2007
Drum not turning
check the motor brushes after taking out the plug
Mar 06, 2014 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
Hotpoint aquarius 1000 extra
have you checked belt or brushes in motor
Jan 26, 2012 | Hotpoint Washing Machines
Drum will not go round on cycle
sounds like your motor brushes have gone depending on what make of washing machine you have I cant help you futher it is difficult to solve without make or model
Oct 18, 2011 | Hotpoint Aquarius WF210 Front Load Washer
How do you change brushes on a hotpoint aquarius washing machine
I have a Hotpoint Aquarius WF740. This does have brushes. Tilt the washing machine backwards & look underneath. The brushes can be seen on the motor housing, they are secured by two screws each.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washes but does not spin
May 13, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
WF340 hotpoint aquarius WASHINING MACHINE
Hi, Remove the drive belt from the drum & motor then turn the drum be hand, Is it noisy? if it is then the drum bearings need replacing i have used this website before and they are very good.
Apr 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
How do i change the brushes on my wf250 hotpoint aquarius machine
your machine may have a 'brushless' motor. but generally hotpoint motor brushes are fixed with 2 screws and are in ablack plastic cover and can be seen if you tip your machine back against a wall and look underneath. the motor being at the bottom of the drum, you could remove them wuth a long magnetic screwdriver.
Feb 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wd62p or aquarius washer dryer .fault no drum rotation .moter seems ok carbon brushes ok .belt ok machine takes in water wants to advance .have motor out to check measures 5ohms rotting all...
Hi Fred,
If the motor buzzes, makes little movements but does not have the power to spin, then you need to replace the run capacitor for the motor. It's a big cylindrical one you can't miss.
No real test for them, just replace.
This is usually the fault - worn brushes, stuck brushes or duff capacitor.
(Mine's on it's way out too on an aquarius WD61, but like the plumbers tap - I'll wait a bit before doing it lol! )
Jul 04, 2008 | Washing Machines
try changing the brushes if you cant do it contact a local elctric shop see if they could check it out for free
Apr 03, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
132 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
