Question about AllerAir 4000 Replacement Cotton Pre-Filters for Chemical Sensitivities Air Purifier
How do you install a mass air filter sensor into a 1994 mercury capri just need a few instructions on how dodo so and if any problems arise how can i troubeshoot the issue. ( ignore what product is aout just needed to get this posted)
How to change air filter on 2006 Toyota Hiace SLWB diesel automatic?
Hi josephjohn,Here are instructions on How to Change Cabin Air Filter in a Toyota. It is recommended to replace this filter at every oil change.
Jul 29, 2014 | Filter Queen Defender Air Purifier
Why is my Toyota LC not accelrating beyond RPM 3.
try to reconnect the check engine sign (make the OBD system operative), it looks like the fuel injetion calculator is not working properly
May 11, 2014 | aFe 2005 Toyota Land Cruiser - 4.7L V8 -...
Constant red light
it may need a clean as there is a air flow sensor, if the flow is not right then it will have this on also a faulty sensor will read this aswell.
Mar 24, 2014 | Hoover AH60015 Air Purifier Replacement...
There are 2 holes on underside of filter housing & when turn on filter water , out both holes, why I hate running it as you don't know if you are getting filtered water from both holes.Help
The main problems I'm seeing on these posts for this filter are design and operater issues. 1. I never run hot water through the unit in filter mode. 2. I never run cold water through the filter turned on high (pressure issues arise), it doesn't filter the water any faster. You just want enough flow to run through the filter. 3. The steel sleeve was a good solution (again pressure) but came up alittle short (ie my epoxy fix). 4. The light is powered by a chip batterey that is unreplaceable and may be bad. Try reinstalling the cartridge. I personally pay no attention to the lights other than a clue. I change my filter when the taste changes or there becomes a flow issue. 5.There are filter screens prior the filter that can become clogged if you live in a poor water area. 6. The filtered water only comes out of the spigot and no other leaks (something loose or pressure issue).
Sep 30, 2013 | PUR (FM-9500) Air Purifier
Temperature Coulant Sensor
Under hood, driver side, upper engine area, mounted in end of cylinder head
Jul 15, 2013 | AM Auto Parts 2006 VW Touareg Mass Air...
Air filter install
The sensor sounds like the MAF (mass air flow) and if it is ... you need it! The car will run without it ... but then it should trigger an OBDll code after awhile .... so depending on where you live ... you will not pass a smog test ... if you are in certain USA states
Feb 15, 2018 | Spectre Performance - 9735 - PowerAdder P5...
Code p1330
I would say the problem is with bad fuel or a bad knock sensor.
May 14, 2013 | AM Auto Parts 2000 VW Passat Mass Air Flow...
Air Purifiers Logo
29 people viewed this question
Top AllerAir Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an AllerAir Air Purifier Expert? Answer questions, earn points and help others
