Question about Sprint Hitachi P300 Cellular Phone
Round shadow on the screen. I have replaced the bulb and it is still there.
Flickering shadows bottom 3/4 of the screen flatscreen vizio tv
Hello
To replace the CCFL lamps, you have to disassemble the LCD module. It is a very skilled work, as CCFL lamms are very brittle. and should be handled carefully. It will be best to get this set repaired by any expereinced service technician.
Mar 05, 2012 | Vizio VO47L 47 in. LCD TV
I've had my projector for years now and worked perfectly. But now, there's a shadow on the right side of the screen. I cleaned the lenses and there's still a shadow. With my observations, it looks like...
Remove the bulb, look for any obstructions or damage. If you see none. Replace the bulb, usually replacing the bulb also replaces the lens, the frame around the bulb, and other components all at once making it an easy one stop fix for most visual display problems.
Jun 04, 2010 | InFocus ScreenPlay 4805 Multimedia...
Sony KDF50E2000 Had the bulb changed by a tech. Mar. 2009, in the last few days the message flashes change bulb on the screen, is this something programed into the TV to come on at a certain number of user...
YES, the tech forgot to reset the counter it is in the menu, sorry i don't know exactly where on your model but it should not be hard to find. The blotches are dust in the light engine, this is not fixable unless you replace the light engine. check with a sony authorized repair shop, some of these optics blocks may still be under warranty!! - even if the set is not.
Sep 01, 2009 | Televison & Video
Blue shadow
No. I would suspect it being a Optical Block issue. I is not a pretty repair not to mention the cost factor. If you could get in touch with Hitachi Customer Service they could lead you to s service facility that could comfirm what I think.
Jun 22, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
I have a dark shadow down one side of the screen
replace light tunnel = use service manual for procedure....T.
Dec 13, 2008 | Samsung HLP6163W 61" Rear Projection...
Gray faded look on top to picture
It can be the anty polarizing plastic screen that protects the display.
Often it causes grey or reddish shadows, in that case must be replaced.
Sep 15, 2008 | Televison & Video
Red color halo/shadowing
can you post a pic of your screen to show the shadowing, as red usually isnt affected with coolant contamination it may be a convergence issue. A pic would help me be better able to help diagnose the problem.
May 02, 2008 | Sony KP-53HS30 53" Rear Projection...
Blue screen in uper part of screen
Hi there
Highly unlikly that it would be the lamp causing this error.
Sounds like a faulty LCD to me.
Mar 26, 2008 | Sony VPL-CX75 Multimedia Projector
Rca hd61thw263 61 in. dlp
Seems a lightning strike took out my bulb
eventhough i have a surge protector.
after replacing the bulb perhaps 1 hour later a shadow began to appear at the top of the screen and progressed slowly down until only the edges are visible.
please can you help?
Sep 09, 2007 | RCA HD61THW263 61" Rear Projection HDTV
Round shadows in picture
Sounds like the Bulb is almost out of life or a dustball or something is moving around inside the light compartment. Look in the instruction or user manual on replaceing bulb or opening bulb compartment or call Mits. for a service center in your area. Good Luck
Jun 24, 2006 | Mitsubishi WD-62525 62" Rear Projection...
Sprint Hitachi P300 Cellular Phone Logo
14 people viewed this question
Top Sprint Cell Phones Experts
Dan Shibata
Dan Shibata
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
