Question about Ovens
Amana evenair convection oven
i just bought this oven and i'm looking for the manual.
The only numbers are
ARTC8621SS
thanks
  • Anonymous Mar 14, 2009
    It don't have any model # or serial
5 Suggested Answers
  • 87 Answers
SOURCE: AMANA SINGLE CONVECTION OVEN CONTROL PANEL SOME KEYS INOP
Usually the keypad is separate and connected with a ribbon cable.If so, you just need to order a new keypad assembly
Posted on Jun 08, 2007
  • 306 Answers
SOURCE: the element just exploded at the rear of my oven, it has a 3 to 4 inch split in it.
Is it still in warrenty?
I have seen this happen with the heater coils in my oven. S happens. remove it go to a appliance parts house or online supplier and obtain amother heater coil.
Posted on May 09, 2009
SOURCE: On a Amana EvenAir convection Plus oven the
There is a blower on the top of the oven, which turns on when the oven is hot enough. If the warm/hot air is coming out from top vent corners - this is the blower working. Even if you turn the oven off at that moment, the blower will still work until the oven cools down. This is normal.
Posted on Oct 14, 2009
  • 9 Answers
SOURCE: Amana EvenAir Convection Plus AOCS 3040
Something else you can check while it's preheating: a few drops of cooking oil on the bottom of the oven will tell you if your lower element ("bake") is functioning at all. If it's working, you will get smoke during pre-heat (turn it off!!), if it's not - the problem *can be* in the relay board. Does your "Broil" function work ok.? if it does, then chances are your ERC (electronic range control - the main board that controls all functions) is fine, and the problem is now MOST likely in the relay board. The lower "Bake" element does most of the work in the oven - if the oil trick doesn't give you some smoke, let a tech know that the lower element is not functioning. That will help narrow down the troubleshooting scope.!
Posted on Jan 10, 2010
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
I just bought a home with a GE Profile Convection oven and want to make bake potatoes. There is NO manual, can you help me? Thanks, Jo
Go here and enter your model# as found on label so you can download a manual
http://www.geappliances.com/service_and_support/literature MANUAL DOWNLOAD
Go here first though and it will show you where to find model#
http://www.geappliances.com/service_and_support/literature/ MODEL# LOCATIONS
Jul 29, 2011 | Ovens
Amana convection stove error message f0
hello,
what this indicate from your explanation means that the element of the oven is weak which will need a replacement with a better one the element is in silver color connected to the wires of the power supply
what you need to solve this problem is to open up the oven then trace the wire down to the element it is silver in color connected to the wire remove it with care and then make sure that it of same side and it is tested from the store before living the store .
thank you and thanks for using fixya.
Aug 29, 2010 | Amana AOES3030 Electric Single Oven
Amana EvenAir Convection Plus AOCS 3040: The oven starts to heat up, never quite gets up to temp and then temp drops down. I had an appliance repair man out to look at it and he said that since no error...
Dec 23, 2009 | Amana AOCS3040SS Electric Single Oven
On a Amana EvenAir convection Plus oven the convection blower comes on during the regular bake cycle.
Oct 12, 2009 | Amana AOCS3040 Electric Single Oven
I need a manual;
Have looked with you number but nothing came up But it did show pictures of convection ovens maybe you could look at them , this will give you a better clue as to what model you have .
Jan 15, 2018 | Ovens
The element just exploded at the rear of my oven, it has a 3 to 4 inch split in it.
May 08, 2009 | Ovens
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
May 21, 2007 | Amana AEW4530DDS Electric Single Oven
Ovens Logo
463 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
