Problem for Washing Machines
Generic problem for all Washing Machines
My washing machine will fill with hot wat...
my washing machine will fill with hot water only, no cold water comes out and the machine gets stuck on teh rinse cycle
Best Solution
posted on Sep 12, 2009
Rank: Guru
Expert
Rating: 92%, 852 votes
Check for a cold water supply problem by taking a look at the water inlet valve. Remove the water supply hoses and check the small metal screens inside the openings on the valve (especially the cold water side). Make sure they are free of rust or debris. Check the solenoids. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will need replaced. Sorry for your trouble and I hope this helped. Best wishes.
Was this helpful?3 people thought this was helpful
Solution #2
Rank: Guru
Expert
Rating: 88%, 149 votes
if you have a well or old galvinised pipe for the home then the screen on the cold water valve has plugged clear the screen but do not remove it flush it with a turkey baster and now the reason it gets stuck on the rinse as you look at your water selections you see hot/cold cold/cold warm/cold always on the bottom is the rinse water selection if you have no cold then it can not fill up and advance through the cyc
Popular Solutions for Washing Machines
Maytag Neptune MAH5500B Front Load Washer
1 Solution
Whirlpool Ultimate Care II LSQ9549L Top Load Washer
1 Solution
Whirlpool Ultimate Care II LSQ9564J Top Load Washer
1 Solution
Questions and Unsolved Problems for Washing Machines
I am looking for the largest front loader washing machine. I do not want a lot of options just...
(More)
I am looking for the largest front loader washing machine. I do not want a lot of options just plain and simple.
Which are the best front load washer and dryers?
Washer works fine until it is time to spin. At the end of the wash or rinse cycle, (when it is...
(More)
Washer works fine until it is time to spin. At the end of the wash or rinse cycle, (when it is supposed to spin.) The pump begins and it acts like it wants to engage the spin, but doesnt. If you open the lid and shut it..it will spin like it should. Some times it will work fine with no problems....so it seems to be intermitant. However, it is getting worse/more often. I'm thinking it could be the saftey switch, but not sure???? Help!
My Kenmore 90 Plus Series top loading washing machine does not clean clothes well. It does not...
(More)
My Kenmore 90 Plus Series top loading washing machine does not clean clothes well. It does not remove simple food stains such as chocolate or juice etc. Also leaves a brown stain that is noticeable on white clothes. I suspect that the agitator is not working as well as it did over 15 years ago when the washing machine was new. Is it possible or even worth it to fix?
hi i got a samsung front loader j845. and i want to know is the pressure switch the same as the a...
(More)
hi i got a samsung front loader j845. and i want to know is the pressure switch the same as the a pressure sensor or are these two completely different parts that become commonly confused?
