Question about Samsung WF337AA Front Load Washer
Door not locking
I Push and lock the door. Push start and after 10-15 seconds, the maching beeps and flashes door, door.... I open and reclose, unplug and plug in again. Same result. It worked fine up until now.
  • 93 Answers
Doot lock hook may not be engaging or door lock is faulty- wiggle the door around while pushing on it, check the door hook , replace the electric latch
Posted on Sep 12, 2009
Gibson oven door is locked after attempting to do self-cleaning.
Unplug it. Plug it back in, then press n hold start. Make sure lock handle is all the way locked. You may have to push on the door at same time while locking n unlocking. If that doesn't work, shoot it. Ha
Sep 24, 2012 | Ovens
Stove door locked and continues to beep and flash code F9
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$%^^%$
Mar 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self-cleaning error message f90
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Dryer just says beep beep beep everytime I push start
sounds like you may have a bad door switch(mach thinks door is open when it is not).open door and look on front panel that door pushes into.you should find a small button covered in a grey rubber boot.push on it and listen for a click,if u dont hear a click the switch is bad.if u do hear a click it could still be bad or you can have a open thermal fuse
Sep 29, 2008 | Whirlpool GEW9250 Electric Dryer
Washer (laundry)
try pressing options and select for ten seconds if that doesnt work you have a promblem with the door lock switch open then shut your door firmly try it again if that doesent do it try unplugging the unit for 5-8 seconds then retry if that doesnt do it then pull the bottom panel and look on the left side of the washer there will be a envelope with a tech sheet there with instructions on testing the door lock itself
May 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore elite 790.3670 oven door locked
I held down the clear button for three seconds, it unlocked but still showed the lock button lit. It began beeping over and over. I opened the door and pressed the clear button again for three seconds. It stopped and the oven works just fine now. In fact, I used it right after I got it cleared out.
Feb 07, 2008 | Kitchen Ranges
Kenmore Elite Electric Range, Display stuck on LOC
I pressed the lock icon on the panel and held it for a few seconds and the display cleared.
Feb 03, 2008 | Kitchen Ranges
Oven beeping, door locked F9 error
Have you tried to unplug the range for 5 minutes? That may reset the programming that is going on.
Nov 18, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore dishwasher Lock-On light flashing, will not start
Push the heated/dry button on the dishwasher for 4 seconds and that will unlock the dishwasher. This is just a safety feature that allows you to lock the dishwasher to stop kids from pushing buttons.
If that doesn’t’ work they will send out a tech to fix it.
Mar 07, 2007 | Kenmore 24 in. 15079 Built-in Dishwasher
Samsung WF337AA Front Load Washer Logo
697 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
