Question about Dometic Refrigerators
I just hooked up and the freezer is working but the refer is not. What should I do?
  • 415 Answers
Yes sound common. open the frzr door and look at the rear of it do you see alot of frost if so the coils have frozen and blocked the air to the frig all the cooling comes from the freezer. now then there will be 3 maiin items to check the defrost heater, the defrost thermostat, and defrost timer if not equiped to check out these item call repair person out and if money is tight then remove the freezer items and get your hair dryer out to thaw the evap it is easier to thaw the coil with out the back panel on it will frost up again but will get you by until tech comes out
Posted on Sep 12, 2009
Lg lfx25960st not cool enough
1. What are your controls (freezer & refer) set at?
LG recommends 0 deg for the freezer & 37 deg for the refer.
2. The way a modern refrigerator works is, the freezer is cooled directly and cold air then is blown into the refer section. The incoming vents in a French door LG are at the back, top. Return are at the bottom. Make certain that nothing is blocking these vents and than the refer has good air circulation.
3. Vacuum the coils at the back of the refer. A large build up of dust, dirt, animal hair etc. will affect efficiency.
Apr 14, 2014 | LG LFX25960 Bottom Freezer French Door...
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
I have a G.E. side by side GSH22JFTAWW. Had power outage and hooked up generator and hooked up to refer. Noticed problems with inside lights and disconnected. Found lites inside refer blown and replaced...
if u r talking the compressor rattles when shook all compressors do you didnt have the generator on the wrong voltage setting did u . the lights shouldnt of blown if you did accidently you may of fried your motherboard
Oct 03, 2013 | GE Refrigerators
On my GE GTH21SCXSS, top freezer bottom refer, the freezer and refrigerator settings are on the coldest settings and the freezer won't go below 15 degrees and the refer won't go below 43 degre
Do you see any ice buildup on the back panel of the freezer? You may need to remove the back panel to see if the coils are iced over. Post back your results.
Feb 10, 2013 | GE GTH21SCXSS Stainless Steel (21 cu ft)...
I have a GE side by side Model#Z1SB48DCA, although there is no water hooked up to the freezer, there is a slow dripping from somewhere in the top of the freezer section, how can I stop that dripping
HI,
It is possible the drip is caused by the defrost pan and during defrost the unit is unable to get rid of the water, therefore it leaks into the freezer down the walls and/or into the refer section also under the crispers. I the drain pan is obstructed and will need to be clears to correct the problem you have. This is not a easy job to do, it is time consuming and the top portion of the freezer will need to be disassembled to access the drain pan. If you not very handy, call a service person, it could be pricey though. Good Luck
Oct 26, 2011 | GE Refrigerators
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
Freezer is 18 deg. F. Refer is 62 deg- seems too warm
freezer maybe frosted up not let cool air in refer .or the fan in freezer is not working
Sep 29, 2010 | Dometic RM2652 Refrigerator
Freezer is cold but refrigerator is hot. Fans are working.
your refer is 100 % dependendent on the freezer,
the first thing i would suggest is to check your airflow,
if your fnas are working, are the drawing air off a clear evap coil, is there extra frost in the freezer,
can you feel cold air comming into the refer from the freezer,
on all units there is a damper of some sort, and a return the air is cycled through those and the evaporator.
check these things
Oct 12, 2009 | Refrigerators
Freezer side is working the refer side is not and
With the information given, I would suggest three items to check. The first would be, to see, if the vents leading from the freezer into the refer side are open or not blocked. Cold air from freezer must be able to past to the refer side. Second, would be to check and see, if the fan is blowing. It will not work in the defrost mode. Third, is to look into the wall, at the very back of the freezer, to see, if there is an abundance of ice. If there is, your defrost is failing, or your freezer door isn't closing correctly. Is the door gasket sealing properly?. If your defrost is the problem, it could one or two problems. One problem could be the defrost control has stopped working. The other problem could be the defrost heater has stopped working. If you don't know how to OHM them out, you need to call a technician, take it to a technician, or discard it and purchase a new one. Good luck. I hope, I've helped.
Jul 13, 2009 | Refrigerators
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
42 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
