Question about Christie Office Equipment & Supplies
Christie lamp explodes
Have there been reports of Christie LX 55 lamps exploding?
Christie said the bulb defect had been corrected but the problem persists.
    An user who is expert in 3 categories / brands.
  • 729 Answers
The lamp VIP300w, with Hg
the lamp have the chance to explode,if the lamp used over 2200 hours
you can replace the lamp when it is about 2000 hours
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Posted on Jul 21, 2015
5 Suggested Answers
SOURCE: lamp
Did you reset you lamp hours when you reinstalled you new lamp?
Posted on Sep 09, 2008
  • 81 Answers
SOURCE: I replaced the lamp with the proper part #UX21513
There is no reset button for the lamp. My first resolution would be to unplug the TV, pull the lamp and try to reseat it. Sometimes the contacts are not perfect. Make sure that all panels and doors are closed as many units have a switch that must be activated with a pin on the panel and/or door. This would also keep the lamp from striking.
Also, some units have a default reset and that is done by pressing and holding the on/off button as you plug the power cord back in. Follow up with results.
Posted on Jun 30, 2010
SOURCE: My toshiba projector tdp-mt200 keeps
You need to look for your thermal fuse and replace it, it is old and is failing after being heated for a while The glass exploding.. well that's a worry, however bad, or low quality or counterfeit units can do this.. Either that or the power supply is sensing some fault and is shutting down,you will have to troubleshoot, in that case using the manual. -
Top service and repair manual below user manual... use these to find and repair your fault.
below is the master Google link for manual
Posted on Nov 15, 2010
  • 5370 Answers
SOURCE: I replaced my Sony KDF-46E200
Did you bought the original lamp or compatible lamp or second hand /refurbished lamp. If its compatible lamp then,in some cases the compatible lamp does not support.If its second hand/refurbished lamp then in some cases,the second hand lamp bulb are actually used lamp,so this lamp has very few hours left in it.In that case if works for few hours,but when this few hours gets completed the bulb explodes.---------- Confirm if you are getting brand new original lamp from sony.Get original sony lamp.Keep updated with the details.Thanks.Helpmech.
Posted on Mar 12, 2011
2008 73" rear proj wd-73735. Why doesn't it work after lamp replacement?
if the old lamp exploded you may have a bad ballast. I would try another lamp first to be safe. Be sure the lamp has an Osram brand bulb inside. If there is no name on the bulb, get your money back.
Jun 23, 2015 | Mitsubishi Televison & Video
Lamp hours on christie LX120
VIP300W X4 lamps
Original unit lamp ,USD120
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
Jan 31, 2014 | Christie LX120 Lamp
The bulb in my Toshiba 56hm195 exploded and over the last year about once a week when I turn the TV on the picture will show and then the TV will reboot itslef two or three times. Do I just need a new bulb...
You need to replace the Lamp. There shouldn't be a picture showing if the lamp exploded, however. You can do a simple check by pulling the lamp out and inspecting it.
Jun 06, 2011 | Toshiba 56HM195 56" Projection HDTV
I have a Toshiba model 65HM167. The bulb exploded about 6 months ago so I replaced it and everything worked fine until now. Now the TV will power on and I will get sound but no picture. The yellow light...
Unfortunately lamps go bad without the visible state of being bad. I don't know who or where you bought the lamp from but I order all my lamps through
The clicking sound you hear is the lamp inverter igniteing the lamp but the lamp is bad.
Nov 29, 2010 | Toshiba 65HM167 65" Projection Television
Exploding Bulb
remove the top of the projector (remove the 6 screws on the bottom and the top 2 screws on the back), use canned air, and blow every piece of dust out of every nook and cranny. also, don't get cheap lamps from "bob's house o' lamps". get the AN-XR10XLP/1 from a sharp dealer to get the full life out of a lamp. also, make sure the vents on the projector are not blocked when you use it.
Mar 20, 2009 | Sharp XR-10X Multimedia Projector
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
Eiki lc4300 projector
check to make sure your lamp is completely in and connected properly, and the lamp door is closed completely, if still no light, pull the lamp out and make sure it is not broken from transporting it or handeling it.
Making sure you do not touch and glass portion of the lamp or surroundings. only touch plastic or "metal using clean dry paper towel for metal contact" as skin oil can destroy a lamp.
"If this dosen't help please reply for more help before marking a bad suggestion, thanks"
May 08, 2008 | Office Equipment & Supplies
155 people viewed this question
Top Christie Office Equipment & Supplies Experts
Lawrence Oravetz
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
