On off sw replacement - Computers & Internet
  • Michael Thomas
    Michael Thomas May 11, 2010
    Hello there: can you pleas go into a little further detail like on what kind of a machine and any thing else that could help me with
    Problem Solver:
  • 17 Answers
U wnt replace ur on off sw ? or u wnt make new ?
Posted on Sep 12, 2009
LAARS LX250N-L error code AIR FLO SW and sometimes a HI LIM SW cannot locate the source of the problem?
hi limits are located under where the pipes go into the heater if corroded replace if wires bad replace to test you can jump them at the board only testing if left jumped heater could catch fire
Jun 29, 2015 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Overall I have a switch at each end of the garage with two lights in the roof in between. Sw (A), Lite (B), Lite (C), Sw (D). SW A & D work as three way. I want to change out Sw D to a wall plug a
If this is what you've got:
"S3" are 3 way switches, black screws are the common or shunt. (Adjust colors of wires to what you have).
You can easily change it to look like this:
All S3s are out. Replace one with an S1 (single pole). The other S3 is now the outlet. Silver screw for neutral gold screw for hot. Outlet is always on, S1 controls both lights.
Please note: There are several ways to wire 2 three way switches (S3) to control a light or two. This is just one with a way to change this method to the way you're look for. Your wiring may not allow you to do this as easily.
May 08, 2014 | Electrical Supplies
Not turn the starter
dear . you have problem with ignition S.W . electric part at end of
the ignition lock S.W , need to replace ,
if you need to start ,you can go anther way by connect the start
(Small wire direct to battery (+) ) after you make S.W On and neutral gear box or P Auto .trans.
Jan 14, 2014 | 2002 Skoda Octavia
Fuser unit failure
Remedy:
1.Replace fuser unit
2.Check the harness connection between fuser unit connector and eject sensor PCB ASSY
3. Replace the PS PCB unit
4.Replace the toner LED PCB ASSY
5.Replace the main PCB assy.
You can try to leave the machine power on for 10 minutes maybe this can clear the error. Or power on the machine while pressing the SW supporter,when the front cover is open and check that toner, DRUM and error LEDs light up, and then release the SW supporter. Check that all LEDs go off and press the SW supporter once,and then this problem maybe cleared by that press the SW supporter once again after all LEDs light up.
Apr 14, 2013 | Brother HL-2170W Laser Printer
1999 4 dr sw dohc starts and runs fine for about 10 miles then it just dies could be doing 60 or 25 mph sometimes will start after a minute and other times it takes longer repeats itself
The LW started in 00, if it is a 99 then it is an SW. I would start by replacing the crank sensor which is installed into the rear of the block, behind the starter on the SW. Most likely easier to replace on the LW as they moved the starter to the front of the engine in the 2.2 LW engine. Cheap part.
Aug 07, 2011 | 1999 Saturn Lw 4dr Wagon
Good evening, I have a 2007 1.6 Polo classic trendline which I want to service my self. Is there anything I should look out for and how do I reset the computer?
for the complete service you have to flow the service sch. as change spark plugs every 30 000 k/m
air filter must be clean every . 10 000 k/m replace at 40 000 k/m , replace fuel filter 25 000 k/m ,re set service , S.W off ignition S.W press butom ( on dashbord ) to in , by anther hand S.W on ign.then turn to clock or unticlock until disply ----- then S.W off and On again . it;s reset . Do this step if display inspection also.
Aug 06, 2011 | Volkswagen Polo Cars & Trucks
Not satisfied. still menu, delete, qual, zoom button is still not working
Hello dear, by the frequent use of sw rubber are dirty or worn.
Should clean the contact on the printed circuit and rubbeer sw or replace them.
1S758-139 Rear push button rubber sw.adgubitosi_3.jpgadgubitosi_2.jpg 1S758-140 Delete button rubber sw.
Deputy images for you to do the job.
I hope bin usefull. Regards
Mar 03, 2011 | Nikon D40x Digital Camera
Microwave runs constantly
you have a door inter lock sw/ failure . replace the sw. there 3 .. ir they click there probably good . one of them does not click . primary sw secendary sw . and mont sw . .. a very common problem with all brands of micro's //
Jan 04, 2010 | Maytag Appliances Over-the-Range Microwave...
Headlights and turn signals
make sure to have a good grown going to the hazard light that seems to be the problem
May 30, 2008 | 1984 Ford F 350
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
