Question about Panasonic Lands Phones
Need factory installed remote code for answering system
  • 42 Answers
8. Can I find out what the remote code is on the answering machine from a remote location?
The preset remote code from the factory is 11. However, if you or someone else changed this to another code after the phone was purchased, there is no way to find out what the new code is
from site:
http://catalog2.panasonic.com/webapp/wcs/stores/wwwconsumer/customersupport/faq_telephones.jsp?storeId=&modelNo=
hope that helps!
Kevin
Posted on Sep 12, 2009
I have lost the factory remote What is the code for the device for use of a universal remote Megnadyne is not on device list that came with universal remote
Megnadyne makes many products. I don't know if their remotes use the same code system as lg,sony. and the list of others. Your best bet is to look on ebay for the factory remote of your model number of the megnadyne. 20 some bucks plus shipping
Jul 04, 2017 | Universal Televison & Video
My remote won't work
Many remote controls freeze up and appear "Dead", but some can be instantly brought back to normal operation by following 4 simple steps.
Use these steps on OEM (original equipment) remote controls for TVs, DVDs, Audio Systems, Satellite and Home Theaters.
Note: If you follow these steps on a universal remote control, you will need your universal's owner's manual to reprogram it.
1) Remove all batteries from the remote
2) While the batteries are out of the remote, push and release every button on the remote control one at a time, until all buttons have been pressed and released at least once. This action drains the capacitors in the remote's circuits and causes the remote's brain to go back to factory defaults.
3) Re-install the batteries, taking care to insure each battery is installed correctly. Use new batteries if you are unsure about the batteries you removed.
4) If this Remote Re-Start procedure is going to work, your remote should now be back to normal. Try it.
If your remote works, Great. If not, you can shop for a new OEM remote control at Remotes.com 1 800 Remotes Factory original replacement remote controls
If you need codes for Universal remotes REMOTE CODES COM
Feb 29, 2016 | Televison & Video
Simon 3 calls out invalid when pushing done button
You need to contact the company that installed it originally and have them remotely restore the factory code if not you have to default your system to the factory code.
Mar 14, 2013 | GE Security Simon 3 Wireless Home Security...
How can i get my messages when im not at home?
Yep, Factory preset is 80 but on some of the newer models, you are required to make up your own security code from one of the handsets before you can use the remote access feature.
Jun 22, 2010 | Uniden 5.8GHz Expandable Cordless Phone...
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
TRYING TO INSTALL REMOTE STARTER, INSTRUCTIONS
go to bulldogsecurity.com they have wiring color codes and locations for your vehicle.Also they list any special relays that you may need for factory security.
Please be sure to rate if this helps you out
Dec 29, 2009 | Astra Car Alarm And Remote Starter,...
Installer Code needed for Bosch Security System Ultima 880
Only way is to factory default the unit and then only if the installer code was not locked. Either way the system will need reprogramming.You will need the instalation manual for this or you can try ringing Bosch Technical as they can remotely access systems if set up to do so.
Worth a call either way browse for your local agent.
Oct 11, 2009 | Kitchen Appliances - Others
Put a childs dvd in asking for parental code?
There is a factory preset parental code you need to enter (unless that default code was changed). That factory code is in your user manual. In order the enter the codem, you will need the remote (number pad). The remote can be ordered through Soundstorm for $35.00 and you can download the manual from their knowledge base, just search "SDVD-100". Once you have both, just use the number pad on the remote to enter the factory parental code and the system will unlock.
Oct 05, 2009 | Soundstorm SDVD-100 Car DVD Player
To retrieve messages from another phone.
First, you have to have the remote access code. The preset code from the factory was 500. If no one has changed it, you're in luck. Otherwise, you first have to be at the base unit to change the access code to something you can use. You would press "change", then press and release "setup" until you hear "Remote access code is...", then press "repeat" or "skip" to change the first digit. Press "setup" to move to the second digit. Repeat these steps until you have a 3-digit code.
Accessing the answering system from a touch tone phone:
dial your phone #. As announcement plays, enter the remote access code. The system announces the # of messages, then beeps twice. After the 2 beeps, the system is ready to accept a command. If you just want to hear the messages in box 1, wait 4 seconds and it will play them for you. Otherwise, you really need the whole manual. I have not found any online as yet, but luckily just found mine.
Dec 04, 2008 | AT&T 9350 Cordless Phone
Open Questions:
Lands Phones Logo
1,044 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
