Question about Logitech Clearchat PC Wireless Headset
I have a short wiring in my left ear cup of my Logitech Wireless PRO USB Headset, and sound out of that ear shorts out all the time.
    Problem Solver:
  • 14 Answers
Time for a new pair. If you are not handy with a sodering iron it is best to buy another set. Once the wires are broken inside the insulation the only thing that can be done is replace the wire itself. it is easy to break the wires inside the insulation twisting the cord, pulling or yanking the cord, along with blending the cord in a sharp bend acn damage this cords that they put on products today.
Posted on Sep 12, 2009
Left channel no sound on logitech headset
Usually something like this is simply the wire at the headseat becoming broken by twisting and stress. If you gently twist and push right where the wire enters the ear cup. It will work and then stop as the wire make a connection. Unless you can solder you will end up replacing the set. Make sure to try it out on a different pc or mp3 player etc just to make sure it is the headset.
Sep 10, 2012 | Logitech Audio Players & Recorders
Hi, I have a Plantronics BackBeat 903+ and I have a big problem with it. It seems to have a bad contact some where in the left earpiece that every time I just touch it it turns off immediately. Can...
It sounds like there may be a short in the headset. If you are just touching the ear piece and then you hear nothing on that side. If that side has been damaged at all you might want to check for manufacture cracks or loose wiring. If your Plantronics Backbeat 903 is still under warranty you should be able to get another one.
Good luck from Headsets Direct!
Sep 05, 2011 | Plantronics Backbeat 903 Bluetooth...
Logitech headset problems
the problem is with cable(wire)...the insulation got failed nd got short circuited....if warranty period is there u can get it replaced with a new one...
Apr 05, 2010 | Logitech Premium Headset
Left earphone keeps dying out and comes back. Also the red light on the mic keeps coming on which blocks me from talking online.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The problem with this wireless! head set cutting out on the left side is very common for this model. I fixed mine by removing the soft ear cup then the two screws under this cup then carefully pry that top piece off the next lower piece. It will come but it is stuck with some soft glue.
Next, unsolder the two wires on the back of the speaker taking note of the polarity. These wires are what are broken. Undo the screw in the center. With a small screwdriver carefully pry the pivoting cup off the ear piece. It is snapped onto a small ball joint under the screw.
Now remove the four screws and remove the top of the ear piece.
Remove the two screws from the small printed circuit board and unsolder the two speaker wires. You will need to find some new wire that is flexible and not much bigger in diameter. I used some that was too large and had trouble getting the last cap that holds the soft ear cup back on. I also reamed out the holes in the cap and the cup that the wires go through to give them more movement.
Replace everything and solder the wires to the speaker in the same order as removing.
You will need a good small tipped soldering iron.
Good luck
Calvin
Feb 10, 2010 | Logitech Clearchat PC Wireless Headset
Can i repair the cable on my headset myself. their is a short in the wire and no sound out of the left side Logitech USB with in line volume
problem is lately all the higher end headphones and usb sets use microthin wires. there is fine strands like as thin as a string and woven into it is 2 or 3 micro thin copper strands. it may be possible but very difficult...
Oct 04, 2009 | Logitech Precision Stereo PC Gaming...
How do I switch the logitech headset speaker to laptop speaker vis versa?
how to i get my mouth piece working?? Ear phones are working properly
Sep 08, 2009 | Logitech ClearChat Pro USB Headset
Logitech USB Gaming Headset only working out of one ear
I've had this happen twice with Logitech headsets and believe it has to do with the cheap/fine wire they use in the cables. I suspect that a good tug on the cable will snap the wire or some other internal connection.
Aug 25, 2009 | Logitech Premium Headset
Logitech Clearchat PC Wireless Headset Logo
337 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
