Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
My Rinnai is too noisy, attached to sheet rock garage wall but other side is a bedroom. Grandaughter is afraid to sleep in that bedroom. Rinnai rep says the noise is normal....
  • 55 Answers
Is this a rinnai water heater if so the noise likely is normal it is from the enormous amount of fuel that is being burned to heat water quick enough to get hot water to your faucet.
Posted on Sep 13, 2009
Hang a sound bar on the wall
get molly bolts if it sheet rock... find one stud if you can and put a sheet rock screw there to hold it, the mollies out in the span.
Jan 04, 2014 | Pioneer SP-SB23W
My heater works for a while then i have to reset the breaker
Hey Jesse,
Is the breaker on the heater or wall going off?
If it's the wall, then your pulling too much amperage for that wall plug and everything else that is on it. Like my bedroom electrical is attached to my Garage and back yard patio. Too many things working in the garage will flip the breaker. Heaters take up a LOT of amperage! Check for other equipment on the same system. (circuit breaker) If it's the machine's breaker, then it could be the fan getting crud in it slowing THAT down, creating higher amperage.
Dec 04, 2013 | Honeywell Heating & Cooling
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
I am replacing my sink, medicine cabinet and adding a small cabinet below the sink. I need to know how to remove the old and install the new.
The task you are embarking on is a great DYI project. But, be forewarned, it can get tricky. First, make sure the new sink will fit in the space of the old sink. If not do you have enough space for the new sink to fit securely against the wall? Next, remove the cabinet. There should be about four screws. You may also have to use a razor to cut calking from around the outside of the cabinet. Sometimes it's used to fill-in gaps between the tile and cabinet. Remove the cabinet. If the cabinet is setting in the wall, make sure you check and see where the support beams are located. If you are not putting in another wall cabinet, then you will have to know what kind of wall you have. Sheet rock, no problem. Plaster requires a bit more work. Measure the hole, and then you will need chicken wire, lime, plaster, paint, and matching tile. Fasten the wire to beams in the wall. The wire will hold the plaster in place. Let dry, sand smooth then paint. If you have sheet rock walls measure the hole cut the sheet rock to fit. Fasten it to the beams, use plaster or Spackle to cover the holes from the screws. You will need sheet rock tape to hide the space between the existing wall and the sheet rock patch. Smooth on cover the tape with Spackle, smooth by sanding.
To remove the sink: first, turn off the main water supply. Get a pipe wrench and remove any connections. If you're not familiar with plumbing you may want to get a plumber to attach the connections.
Putting a cabinet under the sink is the easy part. Make sure you have the right size cabinet. Get a leveler; make sure the sink and cabinet are level. Depending on your walls, you can just screw the cabinet to the wall. If they are plaster walls you will need wall anchors. That should do it. Enjoy
Feb 23, 2013 | Plumbing
How to add a shower to bathroom
have to open wall , other side of shower if sheet rock is better, replace faucet controls, add new pipe up and install shower head then re close wall.
May 14, 2012 | Home
The wall has a big hole its a sheetrod wall but i want repair the hole instead of remving the sheetrod.
square up the hole screw some wood to the back of the sheetrock where you can attach a new piece of rock all along the seams be sure to set the heads of the screws slightly mud the seams take a sheet rock knife and press the tape into the mud remove air bubbles let dry apply second coat let dry sand smooth not down to tape apply third coat let dry sand and paint
May 20, 2010 | Garden
I NEED TO PUT A FIRE WALL OF 5/8" DRYWALL ON THE OUTSIDE OF A NEW FREE STANDING WORKSHOP ON THE SIDE FACING MY EXSITING GARAGE WHAT IS THE BEST WAY - PATTERN-TO APPLY THE DRY WALL TO GET THE PROPER...
any pattern, whether you lay it on it's side or stand it up will provide the same protection
Make sure the rock you buy is fire rated, not just 5/8 standard rock
Feb 06, 2010 | Porter Cable 7800 Drywall Sander With Dust...
One bedroom in my house is always colder than the others . i have radiators in my house. they are the ones that are in the wall , not the big old ones, they are flush to the sheet rock if that means...
ITS ALLWAYS A GOOD IDEA TO IMPROVE YOUR INSULATION , I WOULD SUGEST YOU CHECK YOUR RADIATORS ARE HEATING UP TO THE TOP IF NOT YOU NEED TO BLEED THEM, AND I AGREE WITH YOU AND PUT NEW INSULATING IN THE ATTIC AND LEAVE THE WALLS TILL LATER .
Oct 21, 2009 | Plumbing
1/2HP garage door opener, model 139.53640srt
SOUNDS LIKE YOU DAMAGED A WIRE. TRY RUNNING TEST WIRES TO BYPASS THE ONES YOU COVERED UP.
WHEN YOU DETERMINE WICH WIRE IS BAD YOU CAN SURFACE RUN IT OR UNFORTUNATELY YOU WILL HAVE TO REMOVE SHEET ROCK TO MOUNT IT IN THE WALL. - DO NOT RUN THE WIRES WHERE THEY CAN GET SMASHED BY THE SHEETROCK OR SHORTED BY A NAIL.
HOPE THIS HELPS
Sep 12, 2008 | Sears Craftsman LiftMaster Chamberlain...
Rinnai 556
money seems to be an issue for lots of us. but if you don't mind a coupla extra bucks get a few axial muffin fans and use them to spread out the heat pattern at your bedroom doors
Jan 18, 2008 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
247 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
