Question about Poulan 952801953 Electric Chain Saw
White wire pulled out of the switch box. how do we reconnect?
  • 42 Answers
If you cant access the switch box internally to reattach, then you'll need to purchase another saw. It will cost more to have an electrical shop or small engine shop fix it, then it would be to buy a new one, that is, if you cannot do it yourself.
Hope that helps.
Kevin
Posted on Sep 12, 2009
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
I have a junction box with a 3 way switch that operates hall lights, and a 2 way switch that operates outdoor lights. I want to replace the 2 way with the Woods timer (59018). I tried following...
Remove timer, and reconnect both switches as they were before starting.
Notice if there is a wire that connects to both switches... this will be the Hot wire.
Then notice that the 2-way switch has two wires.
One wire will be Hot > and this wire connects to timer Black wire.
And the other wire goes to Load (light) > and this wire connects to timer red wire.
The timer green wire connects to bare ground wires.
This leaves the timer White wire > you can connect timer White wire with the other ground wires.... > or look in the back of switch box to notice a group of white wires covered with wire nut > connect timer White wire to these other white wires.
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#59018
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 28, 2013 | Coleman Cable Woods 59018 InWall 7Day...
Wiring problem
11-1-12
Thanks for link to manual.
Solution might take more response for full clarity, and you seem a good electrician.
I have numbered two questions that may be unimportant.
Add a comment, response after 5 pm CST
Here is illustration showing Black Hot and White Neutral in attic junction box, as you described. With black-red-blue wires connected as shown in Broan manual. And each device connected to White neutral wire in junction box.
http://waterheatertimer.org/images/Triple-fan-light-night-light.jpg
You have access to attic, and can drop another cable down wall into switch box. This will give necessary total 4 wires between switch and Broan
http://waterheatertimer.org/OWB1.html
Key start point: Junction box in attic has the Black Hot wire and White neutral coming from circuit breaker box.
This cable powers the junction box.
There are 3 cables in junction box, each cable with black and white.
Cable from breaker box with Hot and Neutral. Cable going to light switch.
Another cable jumps power to next box in the circuit, and will be reconnected when finished, black-to-black white-to-white
Old light switch in wall was single pole.
1) How many cables are inside switch box? Just one cable from attic with black and white wire?
2) 3-way switch is the wrong switch, unless you mean 3-pole triple switch with 3 screw terminals on one side of device?
Here is another link that shows wiring choices if you decide to use 3 separate switches (or timers or occupancy sensor to turn on night light) instead of triple switch: Install triple box.
http://waterheatertimer.org/How-to-wire-switches.html#4-f
Oct 31, 2012 | Broan-NuTone Dryers
Box in ceiling has black wire and white wire & the ceiling fan has white wire, black wire and red wire.
BEFORE YOU PERFORM ANY CONNECTIONS BE SURE THAT THE CORRECT CIRCUIT BREAKER FOR THE BOX HAS BEEN TURNED OFF! You must check for voltage between the white and black wires at the ceiling box with each of your two wall switches toggled up or down ONE AT A TIME!
The green wire in the ceiling box (or bare copper wire) is your ground wire and should be connected to the green wire of the fan, and also should be mechanically connected to the electrical box by a screw or clip. If your system was wired correctly you should find that it already is connected to the box.
The white wire in the ceiling box is your neutral wire, so any and all white wires from the fan should be connected to it. You may have one for the fan motor and one for the light kit if there are two separate whites from the fan. Again, they may already be connected together in the fan/light assembly.
The black wire in the ceiling box is switched on and off from either of the two switches in the room, which I assume are located near two different doors to the room. These are called "three-way switches". They are not marked "on" and "off" on the toggle like any single-light switches in your home. That is why you must check for power at the ceiling box with the switches in each position one at a time to make sure that the circuit is de-energized.
Now for the connections:
You will need to connect both the red and black wires from the fan to the black wire from the electrical box. The black wire in your ceiling box is your "hot" wire and will provide power to both the fan motor (black wire) and to the light through the red wire--(sometimes this wire is blue, for others who are following this post).
With this arrangement, your fan and light will only operate with one or the other of your three-way switches completing the circuit from your breaker box. You will have to use the pull chains on the fan to control the fan and lights. So you will probably want to leave the light "pulled on" so that you can control the room lighting from either of your three-way switches, and operate your fan speeds from the pull chain. However, if you want your fan only on at night you will have to "pull off" the fan's light switch.
You may find all this switch flipping and chain pulling an inconvenience. If so, hire an electrician to install wiring so that the ceiling box will be "hot" all the time to the fan's black wire and the fan will therefore be operated by the pull chain only, and the light kit will be controlled by either of the three way switches, via the fan's red (or blue) wire.
One other caveat before you begin: you must make sure that the ceiling box is rated for and mounted sturdily so that it will support the weight of the fan and light kit. Many ceiling boxes are designed and mounted to support only a light-weight fixture. You don't want your fan to come crashing down from the ceiling!
Oct 15, 2012 | Hunter 52" Ceiling Fan With Light And...
I have a dead short somewhere in the wiring for 6 recessed ceiling lights. How do I trouble shoot this to find the short
Test each light separately.
Black Hot wire arrives at one screw on the switch. The Hot black wire going to Lights connects to other screw on the switch.
The White Neutral that completes the circuit to lights is connected with other white wires that are covered with wire nut pushed to back of box.
Open up light#1, and the Hot and Neutral arrive from switch box.
The Hot and Neutral going to lights#2-6 are also located inside light#1 box.
Check each wire for signs of high heat and burning. Check each wire if the insulation has been sliced, or cut short, or if copper is visible because wire nut does not cover wires correctly
http://waterheatertimer.org/How-to-select-right-wire-nut.html
Disconnect Hot and Neutral going to lights#2-6, so switch is only turning on light#1.
Test if there is a short when turning switch ON.
Then repeat step, so switch turns on light#1 and light#2, but light#3-6 are disconnected.
May 31, 2012 | Electrical Supplies
I purchased a hunter universal remote and have a hunter fan with canopy I am trying to get it hooked up to. I have all wiring configured the way it shows on diagram and still nothing. From the box in...
If everything is wired correctly, disconnect power at the source, then reconnect power and experiment with every possible combination of wall switches and the remote until the fan works correctly. At that point, do not use the wall switches again, ever.
Apr 17, 2017 | Hunter 27187 Remote Control
I have a single pole switch that currently controls a bedroom outlet. i am installing a fan and light in the bedroom. i have a new triple switch that i want to control the existing outlet, the fan and the...
Wiring is not fully described: Location of hot wire and neutral wire from breaker box are unknown.
If Hot wire arrives in ceiling box first, the switch box will not have white neutral wires that are twisted together and covered with wire nut. Neutrals will be in ceiling box.
What is known: You are replacing single pole switch attached to one 14-2 wire going to light.
You are replacing light with a fan-light and replacing switch with a 3-pole TM8111 switch.
You have replaced 14-2 wire with 12-3 wire.
TM8111 wiring shows following link:
http://waterheatertimer.org/images/TM8111-switch-wiring-500.jpg
Fan pull-chain wiring shows following link:
http://waterheatertimer.org/images/Fan-motor-1-344.jpg
Assume neutrals in ceiling box.
Assume Hot wire in ceiling box: Connect 12-3 black wire to black Hot wire. Connect 12-3 white wire to black wire on light. Connect 12-3 red to red wire on fan.
White neutral from fan and white neutral form light connect to other white neutral wires and covered with wire nut.
Wiring at switch:
Black Hot wire from ceiling box connects to A COM terminal.
White wire to ceiling light connects to A SP2
Red wire to fan connects to A SP1
Jun 21, 2011 | Pass & Seymour Legrand TM8111 Three Single...
Wiring Door jamb switch
I'm going to guide you on how to create what is known as a "switch leg".
1- run a 12-2 w/ground wire to the light fixture from new switch.
2- connect black wire "hot wire" to the shiny bronze tinted terminal on switch.
3- connect the white wire " neutral " to the silver connection on switch.
4- connect the naked copper wire " ground " to the ground terminal on switch
5- Disconnect the two white wires in the junction box from each other.
6- Connect the ground to ground in j-box
7- Connect the black to one of the whites in j-box
8- connect the white to the other white in j-box
9- wire nut and tape all connections
Oh and be sure that you turn off the breaker before you start. Hope this helps. Good luck.
Jun 15, 2009 | Gardner Bender #GSW-SK Door Switch
Wiring a ceiling fan w/light
To add to red54's comments:
This is what I believe you have:
- one source in the ceiling box (black & white)
- one donwline circuit in ceiling box going to another wall/ceiling box (black&white)
- on switch wire in ceiling box coming from your wall switch (black & white) -- this is the white wire which will be hot when the switch is truned on
Here's how it should be connected:
- all 3 blacks in ceiling box connected together -- no other wires in this bundle
- white wire (which is hot when switched) coming from switch connects to the black/blackwhite fan wires
- connect all reamining white wires together in bundle
- connect all ground wires together
It's that simple. Trick is figuring out, of the three cables in the ceiling box, which is source, which is downline, which is switch.
Maybe red54's procedure can help you figure that out.
May 09, 2009 | Hunter 22890 52'' Low Profile Plus Antique...
Wall switches do not control fan
Some fans will not operate without the remote, however, I'm not sure if the Hampton Bay brand is one of these or not. Below is how you will bypass the remote if the fan will operate without the remote.
You can try disconnecting the receiver in the canopy of the van (the cover that fits snug to the ceiling) once you have shut off the power source remove the canopy and find the remote receiver.
Most likely it will be a rectangular box with white, black, and blue or red wires attached. Disconnect all wires from the receiver and lay it to the side.
Now reconnect the wires directly to the fan, white to white, black to black, if you have a red wire (or a second black wire) in the ceiling box connect it to the blue wire from the fan.
If you do not have a red wire (or second black wire) in the ceiling box, connect the black and blue wire from the fan to the single black wire in the ceiling box. This method will require you to pull the chain to operate the fan separately.
Dec 12, 2008 | Hampton Bay 52 In. White Redington...
Poulan 952801953 Electric Chain Saw Logo
35 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
