Question about Compaq Computers & Internet
HELP! My new compaq presario cq60 built in microphone wont work. I need help fast, major school project due in two days. My mic worked before, I disabled it because i was trying to so some streaming recording and thought it might mess is up. I reenabled it and the sound control panel shows two of the same mics, one working and one not plugged in, i have a jack i dont use and a built in. I have windows vista prem.
  • 1 more comment
  • fireater989 Sep 12, 2009
    I have 1 mic, the built in, I will try what you said. I just recently downloaded the most recent drivers from hp for everything.
    Before this happened
    Also, not sure how to "delete" one of them. All I see is Disable. They both say High Definition Audio Device, the one that is "Working" is said to have a Riser Analog Jack. The one that is disconnected says Rear Panel 3.5 mm Jack in the Properties.
  • 558 Answers
Do you have two mics or not,well if you have one you may have to delete one of them or both.Reboot the computer windows will install the drivers and this should fix this If not un-install the sound card drivers.Windows should reinstall once you reboot.However before you do make sure you have a copy of the sound drivers to reinstall.
Good luck
Posted on Sep 12, 2009
Testimonial: "I updated both of the drivers, one had an update and I restarted, mic worked, thanks"
"Compaq Presario CQ60-209tu inbuilt microphone
Hi, You may have to take apart the laptop to find the connection problem. In many cases it will be in the hinge. If you are not the fixing type brimg it to a PC shop. Good Luck.
Oct 02, 2011 | Compaq Presario 700 470024-192 Notebook
How to use laptop mic
Go click the Start >> All Programs (or Programs) >> Accessories >> Entertainment >> Volume Control. Make sure the check box for Microphone is not muted. You can also increase the volume of your mike through that settings.
Sep 12, 2009 | Compaq Presario 700 470024-192 Notebook
I?m facing a problem with built-in microphone that its not working after i install XP.
Try going to the control panel,
  1. click on sound's and audio device's,
  2. in the sound's and audio device's propertie's box click the voice tab at the top,
  3. under voice recording check to see if the internal mic is checked in the voice recording, default device box,
  4. if it is click the volume box, a new box will appear that say's recording control,
  5. make sure the microphone has a check in the box,
  6. under microphone click the advanced tab,
  7. in the advanced tab make sure the microphone boost has a check in the box,
  8. go back to the sound's and audio device's propertie's box under the voice tab,
  9. at the bottom of the box under voice click on test hardware,
  10. on some built in microphone's you have to talk into the area where the mic is located on the laptop.
  11. if it does'nt help try using the device manager to resolve the sound issue's, check to see if the device is enabled, if it is use the troubleshooting tab to see if the device has a conflict, if it's working properly it will say this device is working properly, or try using the update driver tab.
Apr 16, 2009 | HP Compaq Presario CQ50-210US Notebook
Microphone,xp isn't running,mousepad (cq60-104tu)
if your system is xp and it has not been removed then
you need to uninstall the vista demo
through control panel add/remove
please let me know
Jan 30, 2009 | Compaq Presario Notebook
External Microphone - Not working
good day
have you tried inserting the microphone plug to the red/pink socket in your sound card?
Sep 20, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq laptop c700's mic is not working (sound setting is ok)
My laptop model is compaq presario c754tu, I have installed Windows Vista Business, and the audio is working fine, but the internal mic and external microphone both work together........i want to mute the internal mic..... how i can do it ? please reply me on my email id i.e. vsdoshi@gmail.com
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
Microphone Presario C700 not working
Just download audio driver from this link
http://www.mmoogle.org/compaqc751nrwindowsxpdrivershowto
I am sure it will work.
May 02, 2008 | Compaq Presario 700 470024-192 Notebook
Microphone on aspire 3680 not working
First u activate ur microphone connection.Click on Start - Settings - Control Panel - Sound and audio device Propeties - Advanced - Options - Properties - Select Mic in volume and check it.
Thanks
Feb 28, 2008 | HP Compaq Presario V5000T Notebook
Not able to speak with mic while using messengers
when in yahoo messenger go to actions then call setup, this will set your microphone up within messenger and let you use it. You may need to try all three types of microphone on the drop down list in messenger to set yours up correctly.
Nov 18, 2007 | Compaq Presario Notebook
Computers & Internet Logo
1,969 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
