Question about Garden
2 cycle leaf blower will not start. If you pour furl inti the carb it will start until fuel is gone. I have rebuilt the carb with new gaskets and seals.
  • 248 Answers
Does it have a clear primer bulb, and are you using it when starting a cold motor? The primer bulb should be filling up with fuel after you push it in several times. If you are not getting fuel in the primer bulb then there is no fuel supply. One common cause of that, in old leaf blowers, is a broken flexible fuel line going to a weighted fuel filter in the tank. The flexible line allows the fuel pickup (the weighted filter) to remain at the lowest part of the tank when you hold the leaf blower at different angles. Another cause could be a bad adjustment of the float valve, or clogged fuel passages. Did you blow out all the fuel passages when you rebuilt the carb?
Posted on Sep 12, 2009
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
I rebuilt my 6o5o nikki carb on my snapper leaf blower and it wont start any ideas on how to fix this
Have you tried spraying carb cleaner or straight fuel in carb and try to start. this will show if it is a fuel issue. You also may have to adjust the carb if it has a high and low or idle screw. Also could be the kill switch. How about the fuel lines are they connected correctly and is the fuel filter connected correctly.
Nov 09, 2013 | Garden
Have a husqvarna 125b have spark and fuel wont start done every thing i know new plug rebuilt carb gaped coil im tired of pull on it any answers please help it
the rule of thumb is spark, fuel, compression. I found I gad a plugged air filter. It would not start until I removed it and tried to start.
May 07, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Craftsman Leaf blower with new carb won't start
check the head bolts to make sure they are tight
Dec 16, 2011 | Craftsman Garden
Blower does not seem to be getting fuel, last few usages required chock on to run, will start if gas poured in intake, but will not continue to run. cleaned out carb and fuel lines. What is the likley...
carb needs to be removed and thoroughly cleaned out,and rebuilt from varnish in the oil/gas mix,also remove the muffler and de-carbonize this also as it will create back-pressure and slow the rpm's and power output after time
Mar 23, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Ryobi backpack blower will run all day with choke up but as soon as I pull the trigger it starts bogging down
Thats a lean condition. Check fuel lines and fuel filter. If the fuel ilnes are discolored or stiff or really super mushy, If the fuel filter has become detatched from the fuel line then the fuel lines need to be replaced.
If the carb can be adjusted you can try to adjust but its likely that the carb should be rebuilt with new diaghrams and gaskets.
Adjust by turning the low speed screw out ( counterclockwise) 1/2 a turn. The low speed screw is always the one closest to the motor and usually marked on the carb body with an 'L'. When you richen a motor up the idle will drop so you will probably have to turn the idle screw in 1/2 a turn. 1 and 1/2 turns out from light bottom is standard starting point ( 2 turns for poulan products). If you get more than 3 and 1/2 turns out on the low speed screw or if turning the screw has little or no effect then the carb should be rebuilt.
Dec 12, 2009 | Ryobi Backpack Blower 25.4cc
CRAFTMAN LEAF BLOWER WONT START
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 19, 2009 | Craftsman 4 Cycle Blower/Vac
Craftman leaf blower,not starting,fresh gas,new
How long has it been sitting with gas in it ,did you have gas stableizer in it ,if not disassemble carb and reinstall it will start right up...lou
Apr 22, 2009 | Craftsman Blower Attachment
Leaf blower won't stay running
Replace fuel with clean fuel with proper oil mix. Also the carb. could need cleaning or diaphragm could need replaced. One thing you would need to check that will not cost much but may save you a lot of trouble is the muffler. Check the muffler for obstructions and remove the muffler and check the exhaust port for carbon buildup.
Apr 04, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
278 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
