Question about Gateway Computers & Internet
Wireless laplop, will not access the internet.
I have a gateway wireless laplop, & it keep dropping the internet. Says "local only"
    Problem Solver:
  • 17 Answers
Reset your modem and wireless router by unplugging each for about 30 secs.
Modem first.
Posted on Sep 12, 2009
Magic Jack Plus worked in USB and then Internet on computer stopped working
It's got the wrong gateway setting. Without a gateway (router) to the Internet it can only see local network stuff. I suspect the Magic Jack is still trying to be the gateway but it has no Internet. Stop Magic Jack doing this and it should work.
Feb 27, 2015 | Computers & Internet
I have an unidentified network in my Network and Sharing Center, it will not let me change it to my wireless network name. I can not connect to the internet. how do I fix this?
Manually select Static IP.
First scan for valid gateway ip
Use as a gateway for your wifi
and get internet access..
if u cant get,it is cause of No valid internet access,just they are playing for Network local game :))
Jun 24, 2014 | TP-LINK (TL-WN822N) Pre-802.11n Wireless...
Connecting wireless cam with different ip address
An IP camera is a video camera that can be viewed over a Local Area Network or the Internet. The camera typically is monitored locally from a computer via the network to which the camera is attached. With just a few additional configurations of your network, you can access the IP Network Camera so that it can be monitored remotely using the Internet. This is the benefit of a network camera, as it can reside on an IP network and the video stream can be accessed or saved remotely.
Get the Default Gateway of your IP. Do this by entering "ipconfig/all" in your Command Prompt and hitting "Enter" on your keyboard. Your IP information will be brought up, and number you are looking for is the Default Gateway. This is underneath the IP address. Identify this number by its number pattern, which will look like the following: 111.222.3.4. Access your router. This is done by simply typing the default gateway from Step 1 above into the address bar of your Internet browser, and pressing "Enter." Forward your port by configuring your camera. Open the configuration section on the router web page where port forwarding is located by clicking on the "Applications & Gaming" link along the top of the page. In this menu, click on "Port Range Forwarding." Configuration sections can be located differently with each kind of router. Find this information by referring to the documentation that came with your router when you purchased it. Access your camera over the Internet. To do this, type your public IP address into the address bar of the web browser and press "Enter" in the same way as described in Step 2 when entering your default gateway. Note: The public IP address is different from your regular IP address. The regular IP address identifies computers and other devices on your network, whereas your public IP address is what is used to make yourself known to others on the Internet. Your Internet service provider can supply you with your public IP address if you call them and ask for it.
Viewing an IP Network Camera over the Internet http://www.networkcamerareviews.com/articles/portforwarding.html
Apr 18, 2013 | ASI Trendnet Wireless Tew-639Gr 300Mbps...
Will my 2wire gateway wireless router (AT&t) support the Ipad2? My network is being recognized, and the internet tower icon is shown, but will not safari or anything else.
If you are accessing the internet from your computer through the 2wire gateway, then the problem is with the IPad settings. I have used many of the apple devices on my 2wire gateway, as well as my parent's 2wire gateway. I would suggest taking your IPad to a local apple store, or best buy and see if it will connect to their networks.
Also, if you keep it in a case, 3rd party cases have been known to block wireless signals from reaching the internal antenna well.
Good Luck!
John Vickers
Aug 13, 2011 | 2wire Gateway USB
Access point configuration
Access is easy to configure, you just need to understand basic setup you need to do and just have to find the same options on the configuration page of any wireless access point.
Things to setup.
1. Local IP Address ( You will get default 192.168.1.1 according to your device guide, still you can set different (not recommended, if not expert) )
2. Setup WAN IP-This could be dial up connection (PPPOE) or Internet IP Address provided by your internet provider.
3. Setup Wireless access point SSID, this is what you will find when you scan for wireless connection available
4. Setup security settings. You can setup WPA or WAP to protect security. Just need to select and assign key/password which you will be asked while connecting SSID
Follow the link for exact information on how to setup your Access Point
http://www.tomsguide.com/us/asus-wl-wl330,review-233-3.html
http://support.asus.com/faq/asus-faq.aspx?no=E8D3A5FD-995C-D299-0AE3-FBF28AA04DA6&SLanguage=en-us
http://www.ddp.ru/upload/images/PDF/WL_HDD25.pdf
Hope this helps
Jun 02, 2010 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Aspire 5100 PC Notebook: How do i get my new Acer Laptop to connect to the ...
hi guest, welcome to the forum! Let me think why your laptop cannot access to internet during it's already connected to your router.
1) Because the connection is established --> Wireless is working properly
2) If you cannot access to Internet --> Access Restrictions is configured in Router.
How to configure?
1) Login to Router Administrator, you need to open a command line and use usage as ipconfig and you will see as the following
C:Documents and Settingssin.le>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
IP Address. . . . . . . . . . . . : 192.168.1.102
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
Please open Internet Explorer with the address
http://Default Gateway ~ http://192.168.1.1
You need to know What is User name & Password to login, please configure "Access Restrictions" to allow access
I hope this is your case.
May 18, 2010 | Acer Aspire 5100 Notebook
Internet connection keeps on dropping
Can't seem to find the manual on it but....
Most DSL/Routers have a connection setting in them with 2 settings.
1) On demand (Connects to internet as needed)
2) Always on (Stays connected to the internet)
Sounds like your DSL/Router is set to option 1
Apr 28, 2010 | Zyxel G-4100 v2 802.11b/g Wireless Access...
F5D7231-4 stopped connecting to Internet via downstream router
Why did you change it from dynamic to static? My suggestion would be to put it back to dynamic and let it grab a good ip address from the gateway. The other option is to contact whoever managed the network at your apartment and see what they will charge you for a static IP address.
May 23, 2009 | Belkin (F5D7231-4) Wireless Router
Online gaming drop outs with wifi 2wire modem connection
i got the same problem, quick solution for now is to set the wireless to 802.11b <----, slower local network but shouldnt notice to much on ur internet
still not sure why 54Mbits drops the internet on that modem might need a firm ware upgrade
good luck with that
Mar 25, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
How to wire a ps3
Hey allisc,
In order to connect your PS3 to the internet, you will need one of two things: a hard-wired connection, or a wireless residential gateway. Please keep in mind that your options may be limited by the PS3 model that you own, and that a wireless connection is not possible with some models.
The most straight-forward type of connection you can make is a hard-wired connection - simply use an Ethernet cable to connect your PS3 directly to your residential gateway. By establishing a direct connection, the PS3 should not need any additional information in order to access the internet. The trade-off for the simplicity of a hard-wired connection is that the number of places you can physically place the PS3 itself are limited by the length of Ethernet cable used.
Should you wish to use a wireless connection instead, you will need to own a 40GB, 60GB or 80GB PS3 and a wireless residential gateway. The 20GB model unfortunately does not support wireless capabilities at this time. Please keep in mind that connecting wirelessly can often prove to be more complex than using a direct connection, as you not only need the name of your router, but information on any established security settings as well.
The most common security settings that may be in place are Wi-Fi Protected Access (WPA) keys and Media Access Control (MAC) filters. MAC filters are essentially a series of "blacklists" and "whitelists" that restrict network access based on hardware configuration. WPA keys however, are "passwords" that allow your computer or video game console to decipher a code used by residential gateways which prevent unauthorized users from using your personal internet connection.
Both forms of security may typically be set and changed by accessing the gateway directly through its default website. This default website can vary depending on the brand of the device, but many companies may use one of the two default addresses I've provided below:
192.168.0.1
or
192.168.1.1
Please keep in mind that in order to access the gateway's control panel you will need to have both the admin user name and password!
Once you have gotten access to your residential gateway's control panel, you should then be able to add the MAC address of your PS3 to the gateway’s MAC filters, as well as copy down any WPA key used by the network so that you may later enter it into your PS3's memory.
If you are still not sure how to proceed or do not feel comfortable doing any of this, I would strongly suggest contacting either your internet service provider (ISP) or a Geek Squad® agent at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 10, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
