Question about Konica Minolta DiMAGE G600 Digital Camera
Sustem Error S0042
My 4 year old got a hold of my Konica Minolta Dimage G6000 and now my lens is stuck half way out. It will not move in or out. When it powers on I get "system error S0042." As I do not have a lot of money I am tempted to take it apart and see if I can fix it, but I don't want to make any problem worse. Any suggestions? Thanks, Todd.
See less
    President:
  • 1,884 Answers
Todd, What you can do is to powerit on and try to pull the lens out manually. Do not use too much strength or rotate. But try it a few times and the lens casing may stop touching the camera body. Once the lens comes out fully then the camera will boot up and work.
Posted on Sep 12, 2009
Minolta Dimage S414 does not turn on, displays err message then shuts off? No error code, just err. Been in storage four years, probably stuck lens or something?
Go to this website and try the fixes listed....one of them may "kickstart" your camera.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 29, 2011 | Konica Minolta DiMAGE S414 Digital Camera
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
Stuck Lens
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 12, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Power light blinks, lens door won't close
may be it got stuck try to move it by ur finger cuz mine one opens half some times so move it by finger ..... try it it might work for u ....
Aug 14, 2009 | Konica Minolta DiMAGE X1 Digital Camera
My konica minolta Dimage z2 doesn't focus
Your problem may be that the camera is "locked" on manual focus. If so, you will need to go to the menu, scroll to "2" menu in "P" mode, and click on "focusing mode". From there, hit "single focus or continuous focus." It should correct the problem. Also, is the lens dirty? A dirty lens will not benefit the camera. The light may be too low, also. Try using a flashlight to focus, then take the picture.
Jun 12, 2009 | Konica Minolta DiMAGE Z2 Digital Camera
Minolta Dimage Z1 power quiting
Your power board most likely has a short. You could send it in to mackcam.com for an estimate
Dec 31, 2008 | Konica Minolta DiMAGE Z1 Digital Camera
Moon
The lens elements or aperature have become misaligned or stuck. You might try selecting various focus and digital/analog zoom mode settings.
May 31, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
Konica Minolta DiMage Z5
The odds are you have a broken spring in the anti-shake assembly which has allowed the lens unit to shift to one side. The smudge you are seeing is the edge of the lens housing and will have a slight rounded shape. As you zoom in, you are extending the lens past this area so it no longer shows.
Feb 28, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta DiMAGE G500 5 MP Digital Camera
your lens mechanism is stuck up! try pulling the lens with slight force, if you are lucky the culprit that is blocking the mechanism will get loose. If you are not lucky theres no way you can remove or fix the problem than sending it to the authorized service center. =-( All digital cameras has a a life expectancy of around three years, or 5000 shots. Here in the Philippines, we use conversion method, since all cameras today are made of plastics, we convert those easy to break parts with metal.
Aug 13, 2006 | Konica Minolta DiMAGE G500 Digital Camera
Konica Minolta DiMAGE G600 Digital Camera Logo
256 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
