Question about Kenmore Washing Machines
How do I change the belt on my Kenmore 110.16962502
  • Kenmore Master
  • 8,220 Answers
On this model their is no belt. It is way easier to fix than the old belt drive kenmore. Here is the part. Take a look at some repair pix and review the manual on these beautys.
Posted on Sep 12, 2009
Testimonial: "Thank you so very much.For the first time, I did great. I greatly appreciate your very detailed directions and pictures. "
How do u put a kenmore dryer belt on do u have a diagram?
all kenmore dryers much the same procedure to change the belt
the casing has to be opened
some dissa sembly required
link as an example of how its done on any dryer unit
copy and paste link into your search engine
https://www.youtube.com/watch?v=x6zFGUpfC18
or
https://www.searspartsdirect.com/repair-guide/dryer/how-to-replace-a-dryer-drive-belt.html
May 29, 2016 | Kenmore Dryers
Part number 8066065 kenmore heavy duty super capacity dryer electric belt for dryer tub
Hi mousessugar2...
Go to the following webpage and order your belt...it has changed numbers
It is no longer part number 8066065...It is now a Part number 341241.
Please take time to rate me thumbs up.
http://www.appliancecarestore.net/replacement-for-kenmore-amp-whirlpool-dryer-belt-341241.html
Sep 24, 2011 | Kenmore 63942 Dryer
My kenmore electric dryer turns on and heats but the drum doesn't turn?
that would be a broken belt, or the motor, I say belt. You will need to open the top of the dryer and look in the middle of the drum for a belt, which is not there I am sure, here are some websites,Tim:
how to change belt:
http://www.ehow.com/how_4814455_change-kenmore-dryer-belt.html
belt routing Kenmore is same as Whirlpool:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.htm
May 23, 2011 | Kenmore Dryers
How to change a belt on a kenmore 90 series?
Assuming that this is a belt drive Whirlpool / Kenmore / Roper model, See the following illustrated description.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=144&osCsid=8ce08b97af0e0d57b766fab80965bd6b
Newer models use a direct drive system with a Motor Coupler instead of a belt.
If you find you have one of these, see the following for how to change the Coupler:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
Apr 08, 2010 | Kenmore 24032\24036 Top Load Washer
Belt replacment
Here is a diagram from kenmore corp. that should help you out
Maytag Dryer Belt Routing
This is the most common belt routing found on most Maytag brands clothes dryers.
Since you will have everything disassembled to change the belt, this is an excellent opportunity to vacuum out the cabinet to remove dust and lint and perform preventative maintenance on your dryer. When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Dec 04, 2009 | Kenmore 66862 Dryer
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
