Canon makes thick black line when copying - Office Equipment & Supplies
  • 3 more comments
  • crunch18 Dec 10, 2007
    Hi...i keep on getting thick black lines on the page...but it doesnt even make a copy of the paper...just the thick black line
    No...its a photcopy machine. Every time i press the copy button, the machine makes noise, and a blank piece of paper comes out with a large think black line in the center...thanks so much for responding...
    corey
    what is a drum card...and are you sure the Canon NP 6016 has one?...many thanks
  • crunch18 Dec 11, 2007
    I took out the tonner, and theres plenty of ink all around where the tonner fits. I dont see any kind of roller. Its very dark inside and im not sure of what im supposed to be looking for. I saw the picture of the drum roller...am i supposed to remove the whole drum kit?? How do i clean the space where the toner fits in. Its literally full of ink. Maybe when i removed the tonner, some fell in?? Help :(
  • crunch18 Dec 12, 2007
    This is the NP 6016 MOdel...its over 12 years old. Theres no warranty on it. How do i clean the drum kit? Do i have to remove the entire drum kit? I mean isnt it supposed to have ink in the drum kit spill over a little. I mean the actual tonner spills the ink somewhere...and im dont if its not normal for ink to spill in the inside of the drum kit?? please help??
  • 47 Answers
Hi there, had a smiliar problem in the office this week all three printer having the same issue, black lines, all related to the drum kit, either being covered in ink, or in once case it had a break in the roller.
have a look at this pic, its the drum roller for your printer, amazon link
It is normally sits under the printer toner, take the toner out and you should have access to the unit the tonner fits into, if you look at it closly you should see the roller see if you find any telling signs of ink residue/or cracks on it. If you do its most likely the problem.
Hope it helps
Z33m
Posted on Dec 11, 2007
  • Zim Taylor Dec 12, 2007
    Wow. sounds like your toner spilt some of it contents. The best bet is to clean it with a dry cloth, but i would advise you contact canon, if the printer is under warranty they should come and service it. The problem may or may not be isolated to just the drum kit, could be the toner leakage, or something else.
    Hope it helps
    Z33m
Canon IR 2870 copy with a thick black line in the middle of the page.
There are three possible sources of black lines on copies: the original, the scanning process and the printing process. As a general rule, if the line only appears on some documents, the source is the original. If the copier is also a printer but the lines only appear when copying, the source is the scanning. if the lines always appear, the source is a defect in printing. Since black lines can be intermittent, it is best to check all possible sources.
Faint lines on the original might be more obvious on copies. Adjust contrast and brightness settings to reduce the appearance of lines. Lines at the edges of copies can be due to an original being smaller than the copy. Set the copier to enlarge the original, so the edges of the original are outside the edges of the copy, to eliminate these lines. If the original has folds, creases or pasted-on sections, ensure the original is as flat as possible.
Clean the copier glass, using a glass cleaning product. All rollers and belts should also be cleaned, and trays vacuumed, to ensure dust is not carried onto the glass. Copiers with a document feeder move the original past a small area of the document glass. As the original moves, a single speck of dust in this area will cause a line on the copy, from top to bottom. When copying, always ensure the original is completely dry, including any correction fluid and pen markings. https://www.instantprintersupport.com/
May 30, 2018 | Canon Office Equipment & Supplies
Getting a thick black line in copy mode, original copy from wireless computer fine
If you're usung auto document feeder, try cleaning the scanner glass on left hand side of the printer with metho.
Feb 23, 2015 | Canon PIXMA MX452 Wireless Office All In...
How to remove thick black line on copies/fax on Canon FAX-L1000
pull up the upper cover and be sure that the reader glass is clean
Feb 11, 2015 | Canon Faxphone L100
Canon NP6221 copier makes copies with black streak down middle.
I suggest You Go to Official Canon Printer Page For You Canon Problem On Below Canon Page URL:
Copy Has Vertical Black Streaks In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
Black line scan
Open the scanner lid and clean the narrow glass in the left-hand part of the scanning area. Look for remains from ink or corrector at the far end and wipe them out. The narrow glass should be entirely clear to make good copies from the feeder.
Jan 09, 2014 | Canon Pixma MX410 All-In-One Printer
Black stripes on copies using a Canon D1120
Do you use the Doc. feeder? Try to make a copy off the copy board glass. Is the line there? Now make a copy with the adf. Is the line there? If so, you need to clean the small glass under the doc feeder. It looks like a glass ****, about a 1/2 inch wide. Clean it with windex and that should solve your line problem...
May 11, 2010 | Canon CLC 1140 Copier
When making copies a solid black line (1 inch thick) prints on the top of left side of the page.
Is it From top to bottom? if it is, clean the optics unit, its lens array and mirrors.
Jan 14, 2010 | Canon imageCLASS D320 Digital Copier
Black copies canon laser class 510 only when using the adf. copies fine from the glass.
Are the copies solid black or black lines ? If there are black lines, try cleaning the **** glass under the ADF ( above the large glass ).
Oct 09, 2009 | Canon LaserCLASS 510 Printer
Black at the bottom of scanned pages
There should not be a thick black line at the bottom, but could be from several things, light coming in from somewhere is my first guess, toner is almost out or the ribbon is getting stuck on the inside at that point. You may have to call Cannon and ask them.
Aug 21, 2009 | Canon DR-2580C Path-Through Scanner
66 people viewed this question
k24674
Marvin
Marvin
