Question about Sharp Televison & Video
Bought my sharp aquopus 26"er a few years ago. just got HD box and signals. dpi stuck at 480. how do i change to 1080 which is what the unit is rated for?
    Problem Solver:
  • 6 Answers
I'm not sure what HD box you have, but if it is DirecTV it does that sometimes. Just reset it and try again. Sometimes it doesn't sync correctly with the TV. Once you get it right though just leave it alone, though, or it'll probably do it again.
Hope that helps!
Posted on Sep 12, 2009
How can I get my sharp tv to go back to 1080 pixels from 480pixels...
the 480 or 1080 refers to the number of scanning lines top to bottom and is usually automatic. The correct signal for 1080 must be connected to a 1080 input-----if using a box for signal problem could be coming from there.
Aug 27, 2012 | Televison & Video
THE HD INPUT WENT TO 4810 RATHER THAN 1080, ANYONE KNOW HOW TO TURN IT BACK
It is determined by a box if used, a setting in the box or set and in some cases the box automatically determines the 480/1080.
I can also be use of the correct input (component versus HDMI)
Often overlooked if a box is to reboot the box itself (unplug power for a few minutes to box) Plug it back and allow it to reboot---this problem is rarely in the set---contact your signal provider if you cannot resolve it.
Apr 01, 2012 | Daenyx Televison & Video
Not getting 1080 signal only have 480 on my sharp aquos
What are you running to the tv? a cable box, hd box, p3s?
Dec 14, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
It say 480 stretch on the screen how do I turn it to 1080 for my Hd tv
Make it sure that you have a 1080 signal from your source(eg. HD receiver, bluray player etc.). Try pressing format button on the remote until you get full picture . Or try changing the format or aspect ration in your satellite or cable box.
Dec 29, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Video set on 480 how do i set it to 1080
Should be able to change HD format by tv remote, cable remote or whatever box controller connected to tv.
Aug 22, 2009 | Sharp Aquos LC37D44U 37 in. LCD HDTV
How do I reset big screen tv to 1080 on remote
You don't.
It should automatically switch to 1080 when and only when there is a HD signal present. Otherwise it will be in 480 and you will need to use the format button on the remote to change the picture size. If it does not switch to 1080 and you know for sure you have a true HD signal present, there is a problem with the unit.
Hope this helps,
Skyassoc
Jun 28, 2009 | Mitsubishi WD-62531 Projection Television
High Definition--WS-55807
IF the MITS has 3 component inputs blue red yellow RCA jacks on the back then yes at 480 or 720p, you'll need to attach 2 audio cables for sound. If it has a HDMI input then absolutely.
please rate!
Mar 11, 2009 | Mitsubishi WS-55807 TV
How to change picture quality from 480 to 1080?
needs to be hooked to the tv with either an hdmi cable or componet(blue/green/red.yellow/white/) also check the game on the back of the box. some games are only made for 480 and 720
Jan 02, 2009 | Olevia LT37HV 37 in. HD-Ready LCD...
Phillips hdtv
if the cable box is sending in 1080 signal the tv will not be able to format to a 480 (you can switch to either/or)
the problem you have is if your not sending 1080 to the tv your not really watching HD but you cant strech the 4:3 (non HD channels) to the 16:9
the only thing you can do is run analog signal and a digital signal then switch between the two sorces for your HD and non HD programs
Mar 11, 2008 | Philips 42PFL5332D 42 in. LCD Television
No AVC media box
You should be able to use this with only the DVI connection as just a large monitor. You can use a DVI to HDMI adapter as I do believe the display is HDCP compliant. Many AV receivers will upscale to the necessary 1920x1080p resolution that the display needs.
Oct 29, 2007 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
Televison & Video Logo
70 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
