Question about Acer AC 713 17" CRT Monitor
Monitor display my monitor is working correctly but when i run a game like red alert on my pc the view is distorted also its always distorted and wider than the screen when i run my pc while it is in the DOS mode but when the win. is started it is fixed.
4 Suggested Answers
Trust Me
  • 26 Answers
SOURCE: Monitor off centre when booting up into dos
The monitor likely auto-synced off centered on that resolution because it couldn't find the edges of the black screen.
Try to figure out what resolution the DOS screen is using and then set windows to that resolution and then proceed to center the screen using the monitor's menu.
You can now switch back to the resolution of your liking.
On next reboot, the monitor should keep the settings for that resolution.
Posted on Feb 22, 2008
  • 68 Answers
SOURCE: Distorted digital photos
Most likely the resolution of your desktop has and aspect ratio that in incorrect for your monitor. The native resolution of that monitor if 1440x900. Use the Windows (if using windows) desktop properties to set the desktop resolution to 1440x900.
Posted on Jun 09, 2008
  • 11361 Answers
SOURCE: Started pc in safe mode. Monitor comes on but
Try it on another PC first just to make sure it is not the PC problem, you can also try to set the resolution to 640 x 480 @60 Hz when you are in safe mode, reboot the PC and if it displays OK, then set the resolution to the monitor native resolution which is 1440 x 900 @60Hz.
Posted on Mar 13, 2010
  • 1607 Answers
SOURCE: My H233H monitor is connected to my 8-year-old
The ability to view in wide screen mode without any distortion depends on your graphic card. Try setting your screen resolution to "1280x720" and try viewing the panoramic photos again.
Posted on Aug 10, 2011
0 characters
1 Points
There are these lines of static, distortions across my screen that only visible in certain situations. For instance, as I am tying this the bottom of the words 'static, distortion' are distorted (looks...
Go into control panel, properties, advanced, monitor, refresh rate and select display refresh rates that my monitor can display and then choose which one best suites you and your problem.
Jun 26, 2010 | Gateway FPD2275W LCD Monitor
Im using an lg studioworks 755e monitor and it's distorted beyond believe, for no reason, i tried a system restore and have played with the osd, and some of the options (distortion and size) won't work at...
Thank you for your question.
Fixya has many manuals online to view and download to assist in problem solving.
Your manual is at the link provided.
I would suggest you download it, it is a small file of 2Kb and on page A11 you will see that you need to turn on the "degauss" function. This is essential on CRT Monitors.
Also another idea is to ensure that you don't have speakers placed too close to the CRT Monitor, they will "mess" with you display, if this is the case, move the speakers away from the monitor to correct this situation.
Hope this works for you.
Kind regards
Apr 27, 2010 | LG Studioworks 775N 17" CRT Monitor
Heat from monitor
The monitor,screen,adapter or display of a computer is the primary user interface. Monitor problems are some of the most common computer problems since the voltages inside a monitor can be as high as 10 KV. Many of the problems can be fixed yourself by simply changing the settings but in a few cases you may have to either replace or repair the monitor.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); How to troubleshoot and fix computer monitor/display problems
1. The monitor/display flickers
Check the refresh rate. If the refresh rate is 50 Hz/ 60Hz (depending on which country you stay), it can be affected by interference from electrical power signals like those from fluorescent lamps . Increasing the refresh rate to 72Hz is recommended , since higher refresh rates reduce eyestrain and headaches
2. The display works fine initially, then after some time there are black lines on the screen and then the display disappears
There is a problem with the copper windings in the CRT monitor which are getting heated. It is better to replace the monitor
3. For a new monitor, you get a blank screen or distorted image.
Many monitors, especially LCD monitors, can only handle resolutions which are less than the native resolution, so set the resolution at the native resolution only. The native resolution of a LCD display is lower for smaller LCD screen sizes, typically 1024 X 768 for 15" LCD. CRT monitors have a better resolution than LCD displays
4. The display on the monitor is not steady
This is a result of power system interference from users of the power grid, particularly UPS, power tools and heavy machinery. Try changing the position of the monitor.
5. There is a shadow on the images on the display
Try reducing the contrast setting on your monitor.
6. Monitor becomes blank occasionally
Could be a problem with the display card, check with another monitor. The monitor display cord and power cable should be fixed properly and there should be no loose connection.
7. Dark Spots on the Screen.
Move speakers,USB modem and other magnetic devices away from the monitor.
8. Incorrect Colors - red may become dark brown, blue becomes purple.
Check your video cables and connectors for bent or broken pins and wires. Sometimes there may be a problem with your display card, which can be retuned using a software available with monitor technicians.
9. Run Antivirus to scan corrupt software files.Virus cause distorted characters and images.
10. Set your monitor/display pixels to the software requirements. some softwares require higher pixels to run or to be displayed. some media players, web applications, video games applications and photo editors/view softwares have option to view photos on low or high quality
Jan 29, 2010 | Computer Monitors
I'm using this as an additional monitor for a HP 10" netbook and the picture is stretched & distorted & doesn't fill screen. The vertical adjustment just moves the whole thing up and remains...
Solution goes this way, to maintain the aspect ratio of the monitor, take note of this. Your HP 10inch notebook have different resolution compare to your additional monitor, But I'm sure you selected the dual view mode or the duplicate mode that is why you have distorted display on your additional monitor, to let the additional monitor decide and maximize its resolution, try using the extended view option, you can change the resolution of your additional monitor without affecting the resolution of your 10 inch laptop.
Oct 21, 2009 | Acer X183HB Monitor
Distorted display/aspect HP w1907
This is a common problem with wide screen format.
The way I overcome this distortion is to open a drawing program and draw a circle, some programs require you to hold down the shift key to produce a perfect circle.
I then go to the Display Settings and adjust the screen resolution to get the best display that fills the screen and that gives me the perfect circle.
If this does not work you may need to download the latest video driver for your graphics card and then adjust the screen resolution..
Aug 22, 2009 | HP w1907 LCD Monitor
Flatron w2043s 20" there is distortion on all letters and numbers etc, its as if its ran out of ink ,spoils the picture big time
The distortion mostly is caused by a wrong screen resolution. Choose another (smaller or larger) resolution and once you've found the correct resolution for your display card tne distortion will be gone.
Aug 03, 2009 | Computer Monitors
My photographs are distorted on my widescreen, how do I rectify?
go into the settings menu for the monitor, properties settings display, and change the resolution to the native resoultion for your monitor, iyt sounds like you arend running it at the proper resolution, also run the driver that came with or is on the website that is associated with this specific monitor, it sounds like it was never set up right
Jan 07, 2009 | LG 22" Widescreen Flat Panel LCD Monitor
My AOC 17" CRT monitor displays large veiw on DOS & some PC DOS games where the top portion is displayed at the bottom of the screen.
sounds like you need to run a screen config wizard. If you have a true Nvidia driver you can do this. Otherwise, re-download the driver from the main website
and it'll work for you
Nov 01, 2007 | AOC CT700G 17" CRT Monitor
Always says: Auto Image Adjust
These are the allowable resolutions and refresh frequencies for your monitor. 1280 x 1024 @ 60, 75 Hz 1024 x 768 @ 60, 70, 72, 75 Hz 800 x 600 @ 56, 60, 72, 75 Hz 640 x 480 @ 60, 75 Hz 720 x 400 @ 70 Hz 1280x720 is invalid but I see that you were having problems at 1024x768 which might mean the refresh timing was wrong. Make sure the monitor tab in the display properties (advanced) is correctly set with 'hide modes that this monitor cannot display' so that the display is locked to the valid frequencies and resolutions. If all else fails look at the game .ini configuration settings. You might be able to set a compatible mode there. Or run the game in a window.
Sep 24, 2007 | ViewSonic VA703B LCD Monitor
Screen Distortion at certain Refresh Rates
Have you connected the laptop to another monitor and use the same refresh rates that cause the distortion? If the distortion appears on a different monitor, then I would have your laptop examined by a pc engineer, but, if the distortion only appears on the 997DF monitor, I suggest having the monitor checked at a repair shop, also, have you tried connecting the 997DF to a desktop PC, and use the same refresh rates?
Jun 16, 2007 | Samsung 997DF 19" CRT Monitor
Acer AC 713 17" CRT Monitor Logo
21 people viewed this question
Top Acer Computer Monitors Experts
Steven Wander
Steven Wander
 Mike M
Mike M
Are you an Acer Computer Monitor Expert? Answer questions, earn points and help others
