Question about Logitech X-530 Computer Speakers
X-530 5.1 no souhd
I can't get any sound from system. i have a new sound card and all devices are working
  • 56 Answers
Will try to check your connection from the speaker to the pc, i think you cannot connect the exact audio output from your pc so you try to change the connection from back of the audio card and play your player from the pc to test the sound...............
Posted on Dec 16, 2007
Cannot detect sound card on hp pavilion desktop windows vista operating system
If a new installation be sure and install the device driver that came with it.
If it is an existing card that stopped working it may need replacing or you may need to re-install the device drivers.
If the sound card is part of the main system board and has failed you can replace it with a new sound card plugged into the expansion slots.
Make sure that the sound was not inadvertantly muted - double click the speaker icon on the task bar.
Try the hardware troubleshooting wizard under control panel.
Sep 14, 2010 | HP Computers & Internet
My sound card is not work on windows vista home premium. previously i have xp on my system and sound card was waorking well. now i have installed vista and and it prompts that no output device is...
1. you will have to use the "compatibility mode" to get the sound card to work that is if it worked in Windows XP it will have to be set up in Windows XP
Here is the knowledge base article for follow:
http://support.microsoft.com/kb/927386
2. copy/paste into the url
3. sometime the drivers for you sound card are not compatible for the new Operating system (Vista) and will need an update or you will have to purchase a new sound card that is compatible.
Jul 09, 2010 | Yamaha SW 1000XG Sound Card
Replace faulty ac 97 with new sound blaster card.
hi, you need to go into your device manager and just disable the AC 97 sound card, them go to the control panel and get into sound options, and selectthe sound blaster as your default sound card o primary device .
Oct 07, 2009 | Microsoft Windows Xp Home Edition Sp2...
I uninstalled limewire off my acer a5g and now my sound doesnt work
Look at My PC - device manager - sound card. If it looks like yellow disclaimer, then reinstall the sound driver with all the complementary programs like sound manager etc. In any case reinstalling the driver must help. If not - delete the sound card device from system via device manager. Reboot the PC. The system will report You about the new device. Follow the on-screen instruction and it will install You all sound drivers. You'll see - it's easy.
Regards.
Sep 13, 2009 | Computers & Internet
Soundcard seagate ST320014A
Sound Not Working (discrete sound card)
You probably need to make sure the new sound card is properly installed. Check device manager and make sure the new sound card does not have a yellow exclamation mark next to it.
If the card and driver are propery installed, then you can either disable the onboard audio from BIOS (enter this when the computer first boots up by pressing either F2 or delete several times)
Or
go to control panel, sound, and check the sound card as the default. Do this for .WAV and .MIDI and whatever else you see.
And that should take care of it.
No Sound (integrated Sound card)
check device manager. This can be done in Win XP by right clicking my computer, properties, hardware, then click device manager. Alternative way to enter device manager is by clicking start menu, control panel, system (performance and maintenance), hardware then device manager.
In the deice manager window see if any question marks or exclamation points are visible.
If so, see if it the mark is for an audio device.
If it is an audio device, uninstall the device.
Next, try to install the sound card driver again. If that fails, the enter the device manager and uninstall the sound card again, restart the PC, ignore the hardware manager, and try to install the sound card driver software again.
Jul 07, 2009 | Intel Computers & Internet
Installed a new Sound Card which does not work.
i think it will only run 1 card at a time so you will need to disable or uninstall the reaktek?
Mar 01, 2009 | Computers & Internet
No audio from speakers--- Abit NF-7 v2.0 MOBO----
Same configuration? (Same: Mobo, Processor, Hard Drive?) Just new case and cables? Do you have onboard sound, are you running a sound card, or perhaps you're plugged into a fancy graphics card sound port?. Try these configuration tips before you tear it all apart: Check your device manager in the system section and make sure your intended sound device is operational with no (!), or (?) alerts next to it. Reinstall any mobo, graphics card, or sound card drivers which run your sound device. AND finally, if you have more than one sound device on your computer (mine has all 3 options I described), make SURE you have the right one selected in your sound manager!
Jan 13, 2009 | Abit NF7 Motherboard
Sound card problem
Did you reinstall the sound card physycally on the main board or did you install new drivers?
You need to check the device manager (start-settings-control panel-system-select " hardware" tab at top, then click on device manager)
If you have your sound card listed in its category (sound, video and game controllers) or listed in the "other" category and it has a yellow ! next to it, you must right click on it and hit uninstall. one of those will cause the computer not to even look for the sound card for install because the computer thinks it's already installed , even if its wrong.
so if you see one of these, expand the + to see the device , then right click on it and select uninstall .
then procede to load the new driver. restart
Regards.
Nov 05, 2008 | E-Machines eMachines Refurbished EMA...
No sound
Depending on your pc it sounds like you just had either a new version of windows put on your pc or you recently wiped it. You need new drivers downloaded for your sound card if you do not still have the drivers disk that came with your pc try to google search a download,
Aug 18, 2008 | Edirol UA-4FX External Sound System
Logitech X-530 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
