Question about JVC RX-8040B Receiver
No sound while playing a dvd jvc8040b receiver
Cant get sound while playing dvd, sound is of with tv input but not fron dvd player
    Problem Solver:
  • 14 Answers
Make sure the the necessary input of the tv is select to be able to play the sound from your DVD. Also check to make sure you are pluging in the sound cords into the input sound of the tv and not the output. Make sure the source of the tv that you selected to play the DVD through has a sound jack associated with it.
Posted on Sep 12, 2009
Cannot play blue ray movie on direct tv
not sure what youre really asking? you cant play a blue ray or dvd threw your direct tv receiver. you can hook it up seperately and change your inputs on tv but not threw receiver.
Apr 04, 2012 | Insignia NS-BRDVD Blu-Ray Player
Cant figure out how to hook up the receiver to my phillips hi def tv and get the sound?
its old model, will not pass hd video, good only for audio. Connections depend on your equipment. If you use a cable box to watch tv, connect cable box audio out rca connectors (red and white), by an audio rca cable, to audio TV input on the back of the receiver. Now when you swith your receiver to TV input you get sound from cable box trough your speakers.
If you use DVD player: connect audio out of the player to dvd audio input of the receiver. Switch the receiver to DVD input, you have sound from DVD.
Jan 08, 2011 | Denon AVR-1403 Receiver
My Toshiba model number 51H83 has picture but no sound. I put a dvd in and the sound worked but when I went back to TV no sound. I dusted the back of my tv yesterday and since then have had no sound. Tv is...
Are you using the rf antenna input for TV or 1 of the VIDEO inputs from a cable box or sat receiver. If the latter check to see if you unplugged the audio fron the box White and red wires from box. If thats ok Plug that dvd player into that input using the cabes from the dvd player .If you now have sound change ables from box. if still no sound cable box bad. If still no sound from that input check for solder connection on input jacks. If antenna input is used replace the tunner intv.
Mar 25, 2010 | Toshiba 51H83 51" Rear Projection...
I just bought a yamaha rx-v365 receiver and hooked to my cable box via a hdmi and optic audio cable. this is working fine but i cant get a dvd player to work via a component and coax audio cable. neither...
Make sure that the DVD player is connected into the correct inputs on the receiver and that the receiver also has the correct input selected to play. If your TV also has component video inputs it is best to connect the player directly to the TV. Otherwise, make sure you have the TV connected to the receiver via component video out.
Nov 25, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
No video when conected to fron av jacks
Try different AV input at the rear or try different source such as DVD player at front where you connector game use different AV cable
Sometime the AV jack input poor contact because for long time you not use it or the electronic switching video inside your receiver is faulty
Cheers
Nov 07, 2008 | Yamaha HTR-6130 Receiver
Sound problems
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Onkyo TX-SR605 Receiver
Panasonic DVD-LS855 wont play to LCD TV
Did you turn on the input of the tv to receive 'external' input.? Did you plug the DVD into the right input?
Jun 18, 2008 | Panasonic DVD-LS90 Portable DVD Player
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
JVC RX-8040B Receiver Logo
149 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
