Question about Canon PIXMA iP90 Mobile Printer
CANNON IP 90 PRINTER PROB: ink try full. how do i clean it? i saw instructions on resetting codes. it will not print at all...HELP...Thank You!
    Novelist:
  • 85 Answers
How to Reset The Canon Pixma iP90 PrinterHere is the reset procedure for the Canon iP90 printer, which uses the BCI-15BK, BCI-115C and BCI-16C cartridges.
Just follow these step by step instructions, to reset the Canon Pixma iP90 printer
  1. Turn printer OFF.
  2. Press the RESUME button together with the POWER on button.
  3. While pressing POWER on button, RELEASE the RESUME button.
  4. Press RESUME button TWICE then release both buttons.
  5. The green LED indicator will start blinking, then stop.
  6. Wait until the Power LED lights are green, then press the RESUME button 4 times.
  7. Now press POWER button OFF.
  8. Turn printer ON again, your Canon iP90 printer should now respond normally.
  9. If you need to unclog your print head click on next line
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Posted on Sep 12, 2009
I had the waste ink full problem and fixed that but now it won't print black and when I try cleaning it reports error 5100 I know all cartridges are full.
Is it canon ip-?
If yes, Try to follow these instruction:
Steps to Fix Error 5100 In the Canon IP- Printer:
  1. Turn the printer off
  2. Remove the cartridge from the printer
  3. Use a cloth moistened with alcohol to clean the surface of the contact / connector terminal cartridge that touches the printer / could also use a pencil eraser
  4. Replace the second Cartridge
  5. Turn on the printer.
Thank you
Jun 07, 2011 | Office Equipment & Supplies
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
Ink absorber if full, contact service provider? is there any other remedy?
There are two remedies for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads
. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error.
Reset the Printer using an iP Tool
iP Tools are utilities designed to clear errors that will appear in an iP1800 printer. Download this iP Tool here.
while the printer is on Run this software
1. Click Reset Main to reset the waste ink counter and
2.
Click Reset Platen button
If errors still persist.
Press and Hold down Reset button and wait until the printer restart.
Release the Reset button and wait until it fully initialize.
Happy printing.
Please comeback and rate this answer.
Thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I recieve a message when trying to use my pixma cannon ip 90 that reads the color cartrige is empty, so i replaced it. still gettin message and wont print.....please help dallas44432@yahoo
Go into control panel, and right click on your printer and select properties. Under maintenance you will find the reset to show the inks as new. Also if you open the top cover while connected to your computer and then try to print a window will pop up asking if you put in new ink, answer yes and tell it which ink is new and it will be reset.
Feb 01, 2010 | Office Equipment & Supplies
Cannon ip90 waste ink tank is full
These is all that u need to do:
4 step to Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
There's a lot of methods and choice on how to reset it and this is all my best to share to you.
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 15, 2009 | Canon PIXMA iP90 InkJet Printer
Waste Ink near full shows on screen. Won't print!
Hi ...
Cannon Pixma MP780 have an absorber and this error is related to this absorber.
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <Stop/Reset> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset.
I would suggest that you take your printer to the nearest cannon service centre and get it repaired.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My cannon iP 2000 keeps that waste ink well is full how do I repair this
No repair is available. There is a little tray under where the cartridges rest and when the printer does a cleaning cycle, it squirts some ink into it. Eventually, the ink builds up and when the tray is full, it's time to change printers. Here is what Canon says:
Ink Absorber Replacement Options This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Try this link on how to reset the ink counter: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=ModelFeaturesTabAct&fcategoryid=257&modelid=10237#SupportDetailAct
Oct 20, 2008 | Cannon Office Equipment & Supplies
Cannon pixma ip1000
..ip1000 questions..
..it's cleaning time, a simple if messy operation. You will have to clean the print head and the waste ink pads, and whilst there might as well clean all the other gunk as well..
..so how to do this ?
..power on, open front, let carrier slide to middle front, pull power cable, pull computer cable.
..Remove cartridges
..by hand slide carrier to left to below the grooves in the upper case front. Clip the grey print head retainer, it pivots to the printer back, it must go up in the grooves, then remove print head, it comes forward..
Sep 09, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA iP90 Mobile Printer Logo
563 people viewed this question
old marine
old marine
