Question about Dryers
I have an electric dryer. It's about 15 years old. The heater element works but the drum doesn't revolve.
    Problem Solver:
  • 6 Answers
This problem sounds like a simple broken belt problem. most dryers, you can pop the top up and it swivels on the back. Then you can see if the belt is intact or if maybe it just slipped off the pulleys. If you can get the old belt out, then you can take it to a appliance store, and they will read the numbers off of it, and give you a new belt. You can easily see how the nes belt goes on by looking at the wear marks on the pulleys and drum. The motor usually has a spring loaded bracket that holds the tension on the belt. If not, you will have to loosen the motor bracket, insert the new belt, and then apply tension to the belt while you tighten the bracket
If this doesn't work, then maybe it is another problem. I had a belt get stuck one time because a rat got caught in the belt and hung everything up. A great rat trap, but a mess to clean up.
Posted on Sep 12, 2009
  • 1,305 Answers
Sounds like the drive belt has broken or come loose. If you can open the front of the dryer, you can replace the belt. If you have the make and model number, visit repairclinic.com for parts. They've got pictures so you can match up easlily
K
Clothes dryer shorts every time I turn it on
I assume this is electric dryer vs gas. You most likely have a electric heating element that has broken, and the wire is shorted to cabinet. If you can see inside element, you can often spot the broken wire. Don't try to fix element, you can't splice heating wire, it wont work. Buy a new element.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/perry_14036f9bc71cde6a
Jan 08, 2015 | Dryers
My zanussi turbodry washes perfectly but dryer no longer works.Green dryer light comes on drum revolves but no heat. Yours feithfully Dalibor
recommend a service engineer check this out.
i could be that the heater element needs checking and or replacing.
or that the thermatic control switch needs checking or replacing.
I am not aware of any internal fuses on this device.
I hope this was helpful.
Jan 11, 2011 | Washing Machines
Zanussi tumble dryer spinning but not heating up
I have same problem and been tol its either the heater or the thermostat inside the front of the drum open circuit hope that helps
Apr 13, 2009 | Asko T701 Electric Dryer
Whirlpool electric dryer not drying
If the drier drum is still turning I would suspect a separate fuse is open for the heating element. Checking this may require openning the back cover. It may also be a defective or open heating element.
Jan 28, 2009 | Whirlpool LER8648L Electric Dryer
Kenmore 84152
On a kenmore conventional dryer they had for a million years the heating element is on the rear of the machine on the right. Some newer models "princess type" have a lower front panel and a heater that just yanks out for easier servicing.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 20, 2009 | Kenmore 84152 Electric Dryer
Trying to determine if it is worth replacing the heating element on a 12-15 year old electric dryer?
Are you kidding me? Light bulbs don't last for 15 years, why would ya think your dryer heating element would last longer. Me I replace the element every time. Todays newr electronic **** is worthless.
Dec 14, 2008 | Dryers
Maytag dryer: pye2300ayw
yes, it will. you should be able to take off the panel on the bottom of the front of the dryer. way in the back is the heating element. do not put your hands in there with the power on, but start the dryer and look in there and you will see if the heating element comes on. it will be like looking inside your toaster.
Oct 27, 2008 | Maytag PYE2300AY Electric Dryer
Dryer doing nothing
The fuse mounts on side of the heater. Its little clip is held to the side of the heater chamber by the same screw which holds the heater element down. It has 2 white wires going to it. Clean out the dryer and check for blocked vent and loose blower wheel. good luck Kimosabe.To access the heater pop the top:
eaf511e.jpgthe heater is on the rear bulkhead, remove the front and inspect the filter area and blower assembly.
Sep 26, 2008 | Crosley CDE6000 Electric Dryer
Ge electric dryer dbsr453 heater element
hi thanks for the question if you have the drum out the heater should be at the back you should be able to see the element
Jul 17, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
Top Dryers Experts
