Hi - My LG Tromm washing machine suddenly won't turn on at all. I am sure the electrical circuit is functional. Any thoughts on how to troubleshoot? Thanks. -DL
  • 1 more comment
  • daniel_lyman Sep 12, 2009
    Hi -
    I am certain that the A/C supply is working correctly.
    My thought was the door interlock, but after opening and closing it many times still no lights on at all.
    Next step?
    I'm not afraid to go into the machine if I can just get some guidance.
    -Daniel
  • daniel_lyman Sep 13, 2009
    OK -- I have removed the door interlock device.
    My next question is: how do I test it?
    The mechanism has four connectors marked #2 #3 #4 #5 where the wires connect to.
    How can I test connectivity?
    Looking at the (plastic) mechanism of the interlock, I see no movement that would open/close a circuit. Perhaps there is a piece missing?
    Thoughts???
    Thanks.
    -DL
  • daniel_lyman Sep 18, 2009
    Hi Vinay -
    No, I do not get any lights coming on at all.
    I have replaced the door switch, but still no lights on the panel.
    I am unsure how to proceed from here.
    Any thoughts/recommendations?
    Thanks.
    _Daniel
    Top Expert:
  • Washing Mach... Master
  • 76,164 Answers
Model number please
Posted on Sep 18, 2009
    President:
  • 1,884 Answers
Do any lights come on when you power it on? It is not only electrical circuits, it is also electronic circuits.
Posted on Sep 13, 2009
  • 10,515 Answers
Check the following :-
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
If you are getting power, like LED are working, You might have damaged the control board.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 12, 2009
  • 601 Answers
The washingmachine wont start due to many reasons. check that the socket is supplying power by plugging another appliance in such as a lamp ,as it does occasionally turn out to be a faulty wall socket. This is only necessary though if there are no led indicator lights lit up on your washer as any light that's on shows that the machine is getting a live and neutral supply from the socket.
The second thing to check is the fuse in the plug. Either put the fuse into something else and check the appliance still works or try another fuse
.Make sure you use a 13 amp fuse . If both of those are OK, then the most common cause for a washing machine that wont start is the door interlock, particularly if the mains lights on the washing machine has come on, but nothing works. However, the fault could also be in wiring to the door interlock or even the door catch not activating it properly, or the on off switch or the main control module.DO NOT work on live washingmachine.Check these .Hope these helps.
Thanks
Smith.
Lg tromm electric heater has no heat
check ur heater element, the hi limit and the thermal cut off fuse.
Aug 27, 2014 | LG Tromm Electric Dryer
Lg tromm washing machine
Is this the actual and complete model number from the ID tag on the unit?
Apr 16, 2014 | Washing Machines
WM2277HW LG Tromm washing machine won't start. Finding correct parts is not so easy. Why?
At 14+ appliance years of age, it doesn't make economic sense to repair it.
Mar 06, 2017 | LG WM-2277HW Front Load Washer
Error message stating waterline connection - water all of a sudden not getting to machine.
well if u have water going to the back of the machine then id say the water solenoid is like to have failed
r u sure that the water is turned or isnt stopped up or something going to the machine
Jan 24, 2011 | LG WM2688HWM TROMM SteamWasher
My LG tromm dryer wont heat and i don't know how ignite the pilot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 02, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
An OE light comes on and the washer won't drain
I had something similar. It turned out that one of the option keys was stuck in an "in" position (did not jump back out after it was pressed) which disabled the functions of all the other keys. The lights in main dial came on but it was not possible to do anything else.
Jul 22, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm wm2277wh washing machine
Is the water valve screens plugged restricting the amount of water going into the washer other wise your pressure switch is reading the wrong water level.
Oct 13, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
