My Canon Pixma ip4300 won't power up at all. I turned it on a week ago and it worked fine. Went to turn it on today and nothing. Can anyone help? Thanks!
The fuse is called a 'micro-fuse' and come in two
packages; one is a cylindrical case with two pins through the board that are
bottom mounted. The other looks like a resistor and mounted parallel to the board. Both will have tiny ratings on
them and require a soldering iron. F... Canon.
Unfortunately these are considered disposable printers. If it won't power on at all even in a known good power outlet there isn't much you can do as the cost to repair it out of warranty would cost more than to simply replace it.
Other than checking the power outlet and the power cable nothing else to do.
hi, 1.Make sure powerchord connected properly&turn the switch ON. 2.Fuse has damaged due to excess/Voltage variations(inside Printer Board),you have to replace the fuse.
I have pixma ip3600 canon printer, been used 8months working fine, but today, when I turn on just wait for little whileand the amber light turn on, and when I open thetop cover the printer head won't move at all, please show me how to fix the problem. thanks. Email ( [email protected] )
