Question about Panasonic Lumix DMC-FZ8 Digital Camera
Similar problem -Error message Remove Lens Cap and press button.
I was taking a walk and was taking photos without any problem. Then all of a sudden, this error message appear. Looking at the lens externally, I cannot find any grain of sand / dirt. From all these postings, it seem to ba a common problem with this model!!!!
Can someone suggest how to open the lens? or any reputable repairer in Melbourne.
Thanks.
After reading di_nick34 solution about removing sand, I removed the lens hood adaptor, and blew air between the gap, re-screw adaptor on. Heard a few clicks - must have broken some minute dust/dirt. Remove hood again, and further blowing. Must have removed the dirt stuck in the gap. Camera now works fine. Hope others with similar problem waill have same success.
Posted on Sep 12, 2009
I have turned camera on and set up to take a photo and the shutter release button will not press in to take the photo. I used the camera yesterday and it worked fine!
Turn the camera on and look into the view finder while you try to press the shutter button. Check the information in the view finder to see whether you are getting an error message. If you see an error message in the view finder, remove the lens cap and proceed to take a photograph but, instead of pressing the shutter button this time, press the button near the top of the camera on the back which says "AF/AE. If the camera takes the photo it means you have somehow initiated the auto focus/auto exposure lock which the camera will not override when attempting to take a photo using the shutter button. When you use the AF/AE button, you override this system. To remedy this issue, when you get the error message try pressing the shutter button again. Also, remove the lens to see if the shutter inside has frozen in the "locked" position. If you find this to be the case you will need to contact Nikon Customer Support. The link for Nikon Support is below. The numbers are half-way down the page.
http://support.nikonusa.com/app/answers/detail/a_id/238
Oct 31, 2010 | Nikon D40x Digital Camera
My camera keeps showing the message System Error (Zoom)
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Jul 14, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
My DMC-LX3 got an error message on "remove lens cap and press any button" when the lens cap have already removed!!! i have tried to take out the battery & sdhc then reload them but the camera didnt...
Lens probably does not extend or retract because of debris or a misaligned gear box. The lens can in about 50% of the cases be repaired without having to replace it. Try to return to manufacturer first. If you're out of warranty, there are third party place that fix them such as camera lens repairs. If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Jun 16, 2010 | Panasonic Lumix DMC-LX3 Digital Camera
Error Message
Try to take off the battery and reset the camera. You can also try to remove the lens and check the mirror opening..see if there is some thing stuck there. You can try to click the shutter while the lens is removed. If this procedure didn't work I suggest calling Nikon for further repairs.
Sep 25, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 29, 2009 | Nikon COOLPIX P90 Digital Camera
Error message- remove lens cap and press > button
Is your lens not retracting?
I've got the same problem and with the lens not retracting - this is why i get the message.
Jul 29, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Lens error
This can work with CoolPix S10
1) Remove battery.
2) Replace Battery (Insure it is fully charged)
3) Press the Shooting/Preview button and keep pressing it while you press the power on button. This tells the camera to go into PREVIEW MODE without checking the lens. See if you can preview a few photos and that it works in preview - If it does NOT I cannot help you here.
4) If the Camera Works in Preview mode then press the Shooting/Preview button to put it back into "Take Photo Mode".
5) There can be a delay but it starts up without the lens error.
6) Make sure the ZOOM IN and OUT works and in most cases if the lens operates then you can take a photo. If the Zoom in and Out does not work you have a jammed lens.
7) If the LENS is Jammed AND it is OUT of warranty you 'might' want to tap the lens barrel against your palm. I have found when you remove the battery you can gently tap the lens into telephoto mode by tapping the back of lens assembly into your palm.
May 28, 2008 | Nikon COOLPIX S10 Digital Camera
For some reason my camera keeps comming up with a "REMOVE LENS CAP AND PRESS > BUTTON" error but the lens cap isn't on the camera :(
it sounds like the lens barrel is out out alignment. Possible the barrel was stuck while it was extended. There is a sensor on the lens barrel asemmbly that must be in the correct position after the camera is turned off. If this doesn't happen then you will get this message..at least this is what I have experienced in my repairs on this camera
Aug 22, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Canon A75 stuck between ON & OFF after uploading photos
My Canon A75 has the EXACT same problem. I have always handled it with care. When I was taking photos with it, the camera suddenly started shutting down without a low battery warning. It just started shutting down, but it stopped with the lens still sticking half way out. Like yours, the top green light flashes when I try pressing the power button. Any ideas?
Dec 16, 2006 | Canon PowerShot A75 Digital Camera
Panasonic Lumix DMC-FZ8 Digital Camera Logo
321 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
