Question about Linksys Wireless-G WRT54G Router
Can't connect wireless printer
I have a Linksys router. I called the help desk and they reset my settings on the router to improve my signal I got all my computers to connect to the new settings but cannot get my printer to connect wirelessly.
  • 1 more comment
  • soroland Sep 12, 2009
    Yes, while it was mostly trial and error, in the end I recall he reset it from WEP to WPA but he did not change the key. The printer is an HP Officejet 6210.
    Although the session was mostly trial and error, in the end he reset the setting from WEP to WPA but did not change the key. The printer is an HP Officejet 6210
  • Chitownbarb
    Chitownbarb May 11, 2010
    What kind of printer is it? That would help if we knew what kind it was.
    Sergeant:
  • 168 Answers
You don't say what changes were made on the router. An educated guess says that the security was changed. If so, the passphrase or security code must be put into the printer. You also did not say what make and model printer you have so I cannot tell you the exact procedure you need to follow. Please understand that I am not scolding but merely stating why I cannot give you more complete info. I hope this helps.
Posted on Sep 12, 2009
  • Harvey Morrow
    Harvey Morrow Sep 12, 2009
    I had a 6210. I believe that it cannot accept WPA. Change your router to WEP (as well as all of the computers) and give them a new key and you should be good to go.
My router isnt sending signal to my printer
The router doesn't send signals to a printer. The Linksys transmits a radio signal recieved by the wireless adapters on other devices, if your printer has wireless compatibility it must be setup on the printer, in the wireless settings. I don't think it's a Linksys issue. It a computer software issue. If you post the Computer Make, Model, and your OS, the Printer Make, mode,l I will try to help you. Is this the first time using the Printer?
Jan 11, 2013 | Linksys Wireless-G WRT54G Router
How to connect a linksys e1500 router to a repeater?
Run an Ethernet cable from one of the LAN ports on the downstairs router to connect to the WAN port on the upstairs router. Result: 100% connection.
Jul 08, 2012 | Linksys E1500 Wireless-N Router with...
My linksys 2.4 had a great signal for months and now u can only get a signal if u are right next to it. Is there a way to fix that or an antenna u can make to give out a better signal
Try shifting the router to a higher channel, like 11. Default settings are congested frequencies in homes. With land line cordless reaching 1/2 a mile, it makes for spotty results. 11 seems to always work.
May 25, 2011 | Linksys Computers & Internet
Very week signal
Since you have problem with your wireless router with its wireless signal what you can do here is to change some settings on its wireless settings to improve the wireless connection.
You can follow the step by step procedure from this link to change wireless settings on your router like its channel to improve wireless connection, just click HERE.
Feb 01, 2011 | Linksys Wireless-G WRT54G Router...
Hi, my Linksys Router stopped broadcasting its signal today for some reason. It was working fine the last few days then all of a sudden it just dropped. Connecting directly to the router works but none of...
Log in to the router and check that the WPA/PSK encryption ID or passphrase is still stored. If you have reset the router it may be that the encryption passphrase has been lost and will require to be re-entered. If you cannot remember it it may be possible to obtain it from the properties/settings dialog box on one of the wifi cards on your home computers.
Oct 19, 2010 | Linksys Wireless-G WRT54G Router
Why does the linksys wireless router ''WirelessG: keep going off/
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Apr 05, 2009 | Computers & Internet
Linksys router vs. hp computer
First of all u should ensure that DHCP server is configured for your required number of computers. this problem seems that you have less clients configured in your DHCP server, existing in router configuration.
Dec 28, 2008 | Linksys Wireless-G WRT54G Router
Can not connect another desk top to wireless router
the link below will show you how to work on the wireless settings of your router and how to connect multiple wireless computers in a single network.
Setting up your Linksys router to have wireless security.
hope this helps, if you have other questions just let me know.
Nov 03, 2008 | Linksys WRT160N Wireless Router
Would a neighbors linksys router interfere with my belkin connection?
do check the signal strength of the wireless connection..you can improve signal by removing any big objects between the compu and the router/access point and/or re positioning the router.also intervening walls will affect signal..the fact that you are getting a linksys signal impilies that your home network signal is weak..hope it helps!
Oct 29, 2008 | Belkin (F5D8231-4) Wireless Router...
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
