Question about Kenmore Dryers
I am getting a f70 error on my dryer - Kenmore Dryers
I have replaced the control board and still have the issue. There is NOT a solution to this F70 error. Sears should Recall the machines.
Posted on Sep 23, 2009
    Sergeant:
  • 222 Answers
How old is the unit?
if it is less than one year it is under warranty and you can get it serviced for free call kenmore,
the problem is the main controller.
Posted on Sep 12, 2009
F70
Whirlpool F 70 error code indicates communication problem between the component electronics and the control electronics.
Disconnect power to the machine for about 30 minutes, reconnect it, and try again. If it doesnt correct it self change control board.
Oct 08, 2014 | Whirlpool Dryers
How to troubleshoot f70 error-code maytag dryer
Go to YouTube and ask your question there; I'd bet that a video or two will come up, thanks!
Sep 08, 2014 | Maytag Dryers
My dryer is displaying F70, and will not work, other than drum light. The dryer is a kenmore smartheat quietpak 9 model 11087081601
The F70 error indicates a heartbeat failure of the central control.
If the error occurs while the washer is running then likely it is a problem with the interface. If the error occurs while nothing is running then the central control is most likely at fault.
If the error occurs while the motor is running then the console/membrane is most likely at fault.
This problem can be caused by a short in the low voltage circuit.
It is a difficult problem to pin down and the parts are to expensive just to replace so I suggest a technician check and repair this problem.
Jan 01, 2011 | Kenmore Dryers
What does F70 flashing mean?
The F70 is an internal control problem. It can be caused by a failed central control board or an interface problem. The way to determine which part is bad when the error occurs is as follows:
  • If the error occurs when the machine is running then the problem is the interface.
  • If the error occurs when the washer is not running the problem is the central control unit.
Nov 23, 2010 | Kenmore HE5 Electric Dryer
F70 Message appears and dryer stops WORKING
The F70 error apparently is a design flaw that happens to many of these machines in this series. It has something to do with a failure of the components to communicate with each other. The main circuit board most likely needs to be replaced hope this helps
Aug 11, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
What is f70 mean
Hi.
F70 is an electronic problem. I expained detains in the tip below.
The tip applies to whirpool built appliances like this Kenmore:
F70 and F71 are two logic board error codes that point at a communication error between the main log
Jul 27, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
What does the code f70 on a kenmore elite dryer mean?
F70 is a "communications error" message and the first thing to check is loose wire connections.
If a loose connection is not found, the controller board will probably need to be replaced.
Please report back here what you find, OK?
Aug 05, 2009 | Kenmore Elite HE3 Steam 8676 Dryer
Kenmore Elite HE5 inoperable and F70 error code.
HI, this error code represent a major control issue within the main control. simply replacing the main control will fix this issue. the logic chips are damaged.
May 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite eletric dryer model 8708
I've never heard of an F70 I have heard of an F07 which is possibly a motor controller error.
Nov 28, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
194 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
