Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Keys arent functioning properly
Everytime i press enter +,- or any of bottom right keys/buttons it jus displays an multiplication symbol over and over again plz help!!!!!!!!!!!!!!
  • Texas Instru... Master
  • 8,073 Answers
Reset RAM . If keys are not working properly, calculator is of no use to you. You should have it repaired.
Hope it helps.
Posted on Sep 27, 2009
How do i get the internet explorer message that appears from time to time off the screen of motorola mc3190 without having to shut it down
The key combination you looking for to close any window or message in a Windows environment is ALT+F4, depending on the type of keypad the Motorola MC3190G are using.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
48-Key Keypad
The ALT functions are indicated in blue on the keypad, so in order to use these, you have to activate the ALT Functions first by pressing the BLUE BUTTON (FUNC) (Right side below ENTER button) and then press the CTRL BUTTON (left side below BKSP button).
After the key combination is pressed, the ALT icon appears on the taskbar on WinCE devices or the ALT icon appears at the bottom of the screen on Windows Mobile 6.5 devices.
Now you can press the "D" button to use F4, this will close any window or message that is currently in view.
38-key Keypad
Press the blue FUNC BUTTON (Right side below RIGHT ARROW button), and then press CTRL button (Middle below UP ARROW button), now you can press the F4 button.
28-Key Keypad
Press the blue FUNC button (Bottom right next to Power button), and then press the CTRL button (Top right side below RIGHT ARROW button), now you can press number 4 to use F4.
Hope this helps, good luck.
Jul 02, 2014 | Zebra Symbol MC3190G Handheld Mobile...
'tab' button doesn't work on Motorola MC3190
You get 3 different keypad models of the Motorola MC3190:
- 28 Key Numeric
- 38 Key Shifted Alpha
- 48 Key Alpha Numeric
So depending on the type of keyboard your model has, using TAB are different across these 3 keypads.
When the FUNC button is pressed the icon "F" appears on the taskbar on WinCE devices or the icon "Blue Circle" appears at the bottom of the screen on Windows Mobile 6.1 devices.
In order to use the TAB function, do the following:
28 Key Numeric - Press the blue FUNC button (Bottom right next to Power button), and press the RIGHT ARROW button.
38 Key Shifted Alpha - Press the blue FUNC button (Right side below RIGHT ARROW button), and press the RIGHT ARROW button.
48 Key Alpha Numeric - Press the blue FUNC button (Right side below ENTER button) and press the number 9 button.
Apr 18, 2014 | Zebra Symbol MC3190G Handheld Mobile...
Hi, can you tell me how I can make a simple program so I can change the Nspire to degree or radian mode without having to go through Settings etc etc? My students frequently make mistakes because it is...
No need for such a program. You can specify the angle unit for a calculation regradless of the angle unit currently set as default.
For the TI Nspire with Touchpad.
Calculate the sine of 30 degrees.
Press the trig> button next to = on the left side of keyboard.
Select sin and press ENTER
Type in 30
Press the key with the question/Exclamation marks.
Use right arrow to highlight the degree symbol.
Press ENTER. No need to close parenthesis.
The answer is displayed as 0.5.
To enter an angle in radian (regardless of the angle unit set as default.
Do as above to type in the function
Type in the angle.
Press the small button marked with Pi and arrow (To the left under the EE button)
Use the arrow to highlight the small superscript r.
Press ENTER
For TI Nspire with ClickPad
Press the trigonometric function key.
Enter the angle
Press the key with infinity symbol, beta, degree (below the Clear button.
At the top of the list where the Pi symbol is you will find the degree,radian, and gradian symbols.
Append the one you want and and press ENTER.
Sep 07, 2011 | Texas Instruments TI-Nspire Graphic...
How do i dim the screen brightness on a dell inspiron 1525 laptop
Look at your keyboard some of the keys have blue symbols on them, that's the second function. At the bottom left of your keyboard next to the control key there's a button that says Fn on it hold that down and then press one of the other buttons to use the second function. The brightness control is the up and down arrows. Hold Fn and press up or down to change the brightness.
Also if your laptop is set to a lower power setting the display wont be as bright. Click on the little battery symbol at the bottom right hand corner of the screen a little menu will pop up that says select a power plan if its set to power saver your screen wont be as bright.
Jan 19, 2011 | Dell Inspiron 1525 Notebook
How do you change the time on the display for the M7208?
Changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316. The 4 top line/feature keys are now used for programming.
the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___"
12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Nov 09, 2010 | Nortel Meridian M7208 Corded Phone
Want to change the time
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
19.- Enter day
Nov 08, 2010 | NorStar T7316E Corded Phone
How do I set the time on an Adidas calculator adh4020 watch?
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial; min-height: 15.0px} p.p3 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; min-height: 14.0px} p.p4 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica} p.p5 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Helvetica} p.p6 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Helvetica; min-height: 16.0px} span.s1 {letter-spacing: 0.0px} span.s2 {font: 12.0px Helvetica; letter-spacing: 0.0px} span.s3 {font: 13.0px Arial; letter-spacing: 0.0px}
I have the Adidas ADH4018 and I assume the controls are the same, unfortunately, Adidas has absolutely no manual online for this watch. I've figured out how to do most of the functions of this watch.
NOTE: For greater setting accuracy, I recommend using a stylus-like object or the retracted tip of a retractable pen (as to not write on your watch) to click the number keys when setting the time and date for the first time.
Set the Time:
To set the time go into time mode by pressing the lower silver button on the right side of the watch face. Then enter set mode (press and hold the upper silver button on the left side of the watch face until your display blinks). Press the number 7 to change the hour, press the number 8 to change the minutes, press the number 9 to start the seconds over at 00. Press the multiplication key (x) to change from 12 hour to 24 hour time modes. When finished press the time mode key.
Set the Date:
To set the date go to time mode by pressing the lower silver button on the left side of the watch face. Then enter set mode (press and hold the upper silver button on the left side of the watch face until your display blinks). Press the number 4 to change the month number. Press the number 5 to change the day of the month. Press the number 6 to change the day of the week (indicated by a small dot above the days of the week abbreviations at the bottom of the digital display. When finished, press the time mode key.
Set the Alarm:
To set the alarm time, enter alarm mode by pressing the upper silver button on the right side of the watch face. Then enter set mode (press and hold the upper silver button on the left side of the watch face until your display blinks). Press the number 7 to change the hour, press the number 8 to change the minutes. When finished press the time mode key.
Turn the Alarm On or Off:
To turn the alarm on or off, first enter alarm mode by pressing the upper silver button on the right side of the watch face. Then press the divide key (÷) to change from on to off or off to on. When the alarm is ON an indicator icon will appear in the upper right of the display in time, date, or alarm mode. When alarm is OFF there will be no indicator icon displayed.
To Use the Calculator Function:
Enter Calculator mode by pressing the Clear All (AC) key on the keypad when in time mode. Use the number keys and function keys to complete calculations. To return to time mode simply press the time mode key.
As of yet I have not discovered how to turn off the annoying beep when you press any button.
Oct 26, 2010 | Watches
How to set the time and date
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
19.- Enter day
Oct 25, 2010 | Nortel T7316E 2-Line Corded Phone
Change time and date on Norstar M7324
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
19.- Enter day
Oct 25, 2010 | NorStar M7324 Telephone
How to change the time one hour ahead
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
5.- Press soft key "CHANGE"
7.- Select AM or PM
9.- Press soft key "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press soft key "CHANGE"
13.- Enter year
15.- Press soft key "CHANGE"
16.- Enter month
18.- Press soft key "CHANGE"
19.- Enter day
Mar 18, 2010 | Nortel Norstar 16-Line PBX Speakerphone
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
137 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
