Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Replaced engine light assembly. Bold vertical line on right side of screen and horizontal line approx 7 " from bottom. Diagnosis?
Turn ribbon over and problem solved.
Posted on Sep 12, 2009
My Samsung PS50A410 plasma TV has developed two vertical lines down the right side, one at 60 mm and the other at 350mm. Both are approx. 20mm wide with an indistinct picture behind.
vertical lines as apposed to horizontal indicate bad lowerr connections in the ribbon cables inside the TV at the bottom sometimes they can be fixed but most times your panel is failed
Feb 12, 2018 | Samsung Televison & Video
VISIO E65 - C3 Got bumped. Now there is a vertical solid bar about 5 in.wide along right side.
A bad ground, bad solder connection or a blown coil driver that handles bundles of pixels can knock out paths as each pack drives about an eight or so of your screen horizontals and vertical pixel lines. Wear gloves and try gently pushing on the circuit boards on the sides and on the metal framing to see if it needs a shim to improve grounding or other contact. Use plastic or wooden shims.
May 03, 2016 | Televison & Video
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
How do you remove the headlight assembly on 1995 ford f250?
  • 1.
    Remove the two upper screws from the headlight housing, using a Phillips screwdriver.
    Locate the two lower retaining nuts inside the engine compartment at the bottom of the headlight housing. Remove the nuts using a ratchet, extension and socket.
  • Separate the turn signal and marker light assembly from the front grill. Rotate the bulb holders counterclockwise and pull them out of the assembly. Set the assembly aside.
  • Unplug the headlight bulb connector from the bulb. Rotate the retaining ring counterclockwise one-eighth turn and remove it from the housing. Pull the headlight bulb straight back and out of the housing. Do not rotate the bulb during disassembly.
  • Lift up on the headlight housing retaining clips to unsnap them from the headlight housing vertical adjuster studs.
  • Locate the horizontal adjuster at the outer bottom corner of the headlight assembly inside the engine compartment. Loosen the horizontal adjuster until it is free of the adjuster nut.
  • Remove the headlight housing from the vehicle.
Installation
  • Install the headlight housing in the front grill.
  • Engage the horizontal adjuster screw with the adjuster nut and screw it partially in.
  • Snap the headlight housing clips on the vertical headlight adjuster studs.
  • Insert the headlight bulb into the headlight housing, flat side up. Slightly rotate the headlight bulb to engage the grooves in the light with the alignment tabs in the back of the housing. Install the retaining ring on the bulb. Plug in the headlight bulb connector.
  • Install the bulb holders in the turn signal and marker light assembly. Install the assembly in the grill. Install the two upper screws, using a Phillips screwdriver. Install the two lower retaining nuts, using a ratchet, extension and socket.
Headlight Aiming
  • Pull the vehicle to within a few inches of a blank wall, on a flat surface. Apply two strips of tape to the wall vertically to mark the centers of the headlights. Apply a strip of tape to the wall horizontally to mark the center of the headlight height. Back the vehicle up 25 feet in a straight line.
  • Turn the headlight low beams to the "On" position.
  • Adjust the vertical headlight adjusters until the high-intensity zone of the light pattern is two inches below the horizontal mark on the wall.
  • Adjust the horizontal headlight adjusters until the high-intensity zone of the light pattern is two inches to the right of the vertical headlight marks on the wall.
Nov 08, 2012 | Cars & Trucks
There is a line down the center of the screen
whether the line-shaped vertical or horizontal? if it appears a horizontal line on your side, it signifies the vertical rays do not exit the screen or your TV vertical part is not working. damage can be caused by IC Vertical, or in the vertical deflection coil yoke.dan if a line that appears is from top to bottom that indicates the horizontal section is not working, usually there is a problem of the deflection yoke is not connected or defective.
Jul 11, 2010 | Televison & Video
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
Green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
157 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
